New Jeep - Gladiator Rubicon
Bobzdar
I put together a bed side rotopax mount using some parts I had lying around and a rotopax L bracket. I used the extra toolbox mounts that came with the Tacoma mount kit for the above trac rac, drilled out the relevant holes on the L bracket to fit the larger bolts and bolted it together. It mounts to the trail rails inside the bed.
I plan to change out the hardware that attaches the mount to the L bracket so I can move it closer to the body using the other set of enlarged bolt holes in the 2nd pic, and add a rubber bumper so it doesn't bounce against the body. The current hardware sticks out just enough to rub against the body using those holes. I might try to rotate it to keep it level with the bed side, but I'm not sure it'll fit. Due to the bump out for the bed light, the brackets can't move back any farther, but it clears the fender where it is, so will work.
Bobzdar
Just out of curiosity, why not keep the jerry can in the box?
I could easily do that (even using the same mount just flipped around), but with the 5' bed I'd like to keep as much space available for cargo as possible.
I can also run the above in conjunction with the rack and locking bubble so it takes up no space in the bed and the mounts serve double purpose. If I didn't already have most of the parts lying around I probably wouldn't have done it, but it was fairly easy and just cost me the $39 for the L bracket.
Jurfie
I can appreciate conserving space in the bed. I think the space above the rear fender might make a decent spot for a shovel (with the head facing back and behind the fender) and/or a hi-lift on the other side.. ?
Bobzdar
Stop, I'm going to have to buy another set of mounts now :) - but yeah, the way the bed/fenders are laid out, there's room to add stuff to the side without reducing ability to squeeze through tight spots, so I may work on a few others. I have a folding army shovel that packs away in my gear bag, so don't think I'll mount one of those, but a hi lift jack and potentially a water can for the other side.
Bobzdar
Haven't done a whole lot with the truck recently (other than drive it), but I did add a tonneau cover for when not running the rear rack. It's made for a '15-up Chevy Colorado with 5'2" bed but fits nicely. It releases via a cable underneath the tonneau, so if the bed is shut and locked there's no access (without cutting it, of course) and so far it hasn't allowed any water in.
I'm gearing up for a trip in Nov in NY, so getting my tent set up with a stove jack. Will take some pics later.
chadwicksavage
I wonder if anyone has considered a soft or hard top that extends all the way to the tailgate. Maybe an easy way to recreate the Africa concept?
Todd780
OverCamper
I've been thinking the same thing. Kinda like a D130 with fulltop.
Cheers
Like these renderings?
Afrika concept for reference:
188997_Les_concepts_Jeep_pour_le_Easter_Jeep_Safari_2015.jpg:
That would be pretty sweet. If someone built them, I'm sure they'd sell a ton.
Jurfie
I like those concepts, but the roof rack on the top one would need to have a separation between the roof and bed topper.
dhuss
