Shifter is mostly installed.  I need to work out if I want the boot on top of the floor, or If I want to cut the floor covering out around the boot.
A few cardboard models, and a couple pilot holes got me the rough position and cut-out.
Because I didn't want to cut out the floor support, I opted to trim the back of the flange off instead.
The tcase  bracket didn't position the cable correctly, I could have made it work, but it was easy enough to cut and move it up 1.5".
Here is everything bolted up.  The seller mentioned I may need to redrill the hole in the selector arm.  THe 242 has more total rotation on the shaft than the 241, and the shifter would not have had enough throw.  I redrilled the hole at a 2.5" arm length.
I should have put the shifter a bit farther inboard.  I will probably just trim the excess on my seat adapter plate, as it sticks out about 0.4".  It really sucks getting these heavy seats out though.
Now I need to figure out the Tcase indicator switch pinout.  Hopefully it indicates all the positions, and I can just put a few indicator LEDs on the dash somewhere.
