Dual tank setup
Ramdough
Make sure the tank is built to be mounted the way you want. Be a bad idea to hang a .100" aluminum in bed tank that has downhand welds.
It is a Kenworth 100 gallon truck side mount tank.
Alloy
There are quite a few of these around used but watch out for electrolysis where the straps were. Like this one.
Always use neoprene (never rubber) on aluminum.
Using Sikaflex 291 (it sticks but doesn't bond to aluminum) between the neoprene and the aluminum will prevent electrolysis.
oskarf150
