reaver
^^Very solid advice here. I've only been doing this for a couple of years now. My current rig is a bone stock 2004 Colorado z71. No lift, mud tires, and a couple of radios. That's it. It's served me fairly well for the last two years. I've learned that for my needs, and what I want to do, it's just not a great fit, at least not without spending probably 6-7 grand, and my options are pretty limited.I have been wheeling for 30+ years (I'm not bragging! I'm just old).... THIS ^^^ is solid advice. Go out and learn the limits of the vehicle, and yourself.
If the TRD Pro comes with a traction device, like e-lockers, your already money up. I can make it most places on 28" tires that some Jeeps struggle with... hey are outfitted with every bolt on in the book~ Snazzy bumpers, winch, arb's front and back, long arm kits, anti rock diso's, 33's... etc.
WHY? Because I know my rigs limitations and use it to the best of my ability. Don't get me wrong, some upgrades will be necessary over time to get where you like to go, but driver skill is worth more in the long run! Knowing how to pick lines, understanding your cog, and how your particular rig might adapt to certain terrain based on the advantages/ disadvantages it has.
This is the typical order of things for myself at least.
COMFORT> This is first. If your gonna camp in it and have fun in the outdoor arena then none of the above matters if you get out there and are uncomfortable! This means the gear you tote along on your outings. Nice sleeping platform/ tent or whatever... good bag... you get the jist.
Just drive vehicle initially. See what gets stressed based on conditions your apt to drive in.
Make sure your tires are adequate~ You wouldn't roll out into a snow storm with slicks, right? If you like basic meandering on and off road. Then a good AT tire will suffice. (To many to list...), If your primarily off the beaten path, then a bit more aggressive. And so on. If it's a weekend warrior, consider a set of rollies for the week commute to work and a set of campers to throw on when you head out for the "getaway"! Yah, it's money up front, but you will love it later when your only buying some new cheapo's for the commute.
Recovery~ winch, come along, shovel, some form of jack/ lift. Straps, shackles a pulley and so on... Lot's of options and opinions here, so do some reading and learning~
Traction~ Selectable lockers are king. E- lockers are great standard! If it's just an offroad beater then throw a Detroit, Aussie or whatever in the rear and maybe a selectable up front. These are costly... so only WHEN needed. IMO it's money better spent than a lift right up front.
A little extra height~ At some point you may want to add a bit of ground clearance... but be sensible! Remember the higher you go, the worse off your center of gravity. Sucks on the steeps when things shift and your top heavy. Also consider the offset of gearing when lifting and adding larger tires! I mean a couple of inches, you probably aren't going to notice a ton of power loss and your speedo might be four or five miles off... but add another few inches on up, things start to add up. Gears, the associated lift, suspension and so on... wait on this as long as you can and just learn to drive and have fun camping/ exploring.
So,instead of spending that money adapting the vehicle, and fixing some design problems with the truck, I've decided my money is best spent buying a dedicated adventure rig.
For my needs, I've chosen a first gen xterra. Good space, strong drive train, reliable engine, and simple to maintain. The only mods I'm planning in the first year are skids and a swing out tire carrier.
I wanna see what the limitations of the vehicle are. When I need to, I'll toss an Arb in the rear, but I'm planning on putting a lokka in the front with manual hubs before I do the Arb. That might be all I need.
But again, I feel it's best to use the vehicle as it is for a while, and see what needs tweaking before dropping loads of cash on mods you may not even need.
