Options for cushion between chassis and subframe
glennm01
What material is considered the best for the layer of cushion between chassis rails and subframe? I've seen HDPE mentioned, and also high density polyurethane, which I'm pretty sure isn't the same thing. If so, any good reasons to pick one over the other? And is there anything else one should consider?
glennm01
Another question -- does the cushion material typically get fastened to the subframe or to the chassis? Or does it matter? And would an adhesive like Sikaflex 252 or equivalent be up to the job instead of fasteners?
john61ct
yes, hundreds of good adhesives.
Bound within say a quad U-bolt not even that should be needed.
glennm01
This is for a Fuso build, so it'll be 3 spring mounts on each side, with the rear of the frame rigidly bolted to the subframe. No U-bolts, as a result. Is adhesive still viable?
seth.c96
