1998 Quigley E-350 with pop top SOLD
ilazonic
1998 E350 quigley with sportsmobile top, solar, homebuild inside 150k miles, V10, 35s, build "move" bumpers, California van so no rust it was a fleet vehicle for first 100k miles after that we got it and did most of the maintenance .Trade only for crew cab 4x4 truck preferable flatbed full size. Serious inquiry only I have no time to deal with tire kickers. 25k $ obo cash is king, rig is located in Gilroy CA
dr. benny
Enjoying The Journey
Does the rear seat have safety belts? Also, can you share a little more about the interior build out? Thanks.
ilazonic
no seat belts bench folds into bed and build out kind of what you see is what you get just cabinets to store stuff everywhere all solar and electrical is mounted in the back with deep cycle battery under the van passenger seat swivels
rhonerides
hi. got a few questions
any drips under the van does it burn any oil between changes? when were the brakes worked on last and any pulling under hard braking? and how tight is the steering and does it go straight down the road? I assume the fridge is I included.any leaks with the top? any rust?
thanks
ilazonic
thanks
Small drip from T case now and then other then that everything is dry and it doesn't burn any oil. Brakes have about 50k miles on them and it doesn't pull while braking. Steering is pretty tight everything was replaced (tie rod ends etc) at 100k but it slowly getting looser I would say another 30-40k miles and it would need replacing. Fridge is up to negotiations and for the top it was leaking before we got it after sealing it and replacing seal around the roof is all good now. We owned it for about 4 years I think. and no rust except few surface spots on exhaust pipe etc typical california vehicle
