2019 Off-road Teardrop Camper
OnBeechRoad
2019 Off-road Teardrop Camper. Clear Virginia title. $9,950 negotiable. Neil 757-374-0571. All professionally TIG welded aluminum frame and body construction. Total weight is less than 800lbs, you wont find another this light. Easily tows behind any mid-sized vehicle. The body is 8' long, 5' wide and 4' tall. Same track width of a Wrangler or Tacoma. Overall length is 12'. There is no galley. Plenty of USB charging ports and cigar plugs all protected by a Blue-Sea fuse panel. Interior lights and a Maxx Fan on the roof. Switches and wiring installed for future installation of rock lights and exterior lights. 12" of storage under the 6" thick queen tri-fold mattress. The walls, floor, and ceiling are all insulated with 1" thick dense foam. Custom padded cloth interior. Interior floor and complete undercarriage coated with LIne-X. My Wrangler hardly felt it while towing it. 6'6"x6'6" Tepui awning on the drivers side and a 6'6"x4'6" Tepui awning on the passenger side with custom Tepui annex and floor. Passenger and driver side door with screens. Leaf spring suspension designed by a local trailer construction company. 3500lb axle with the ability to add brakes if you would like to. I would be happy to answer any questions.
OnBeechRoad
okay...
OnBeechRoad
here's a couple outside, without the awnings...
Heavyopp
What zip code?
how does VA handle home built trailers? Is there a transferable title that’s acceptable in another state?
BeechRoad
What zip code?
It's a clear VA title. Transferable to any state. Instead of "Jayco" for example it says "homemade". My zip is 23434
project13support
