jhoyt
I'm looking for some advice on my ambulance electrical system.
My system is set up almost exactly like the attached diagram from the KKK-1822 specs. The only differences are I don't have an inverter, but I do have a charger. Also, the module disconnect switch is actually a module power solenoid.
I have one battery under the hood, and another two in the battery compartment in the patient module. They are all ganged together to make one large power source, as in the diagram. I'd like to have a separate deep cycle battery bank to run a fridge, lights, usb ports and a water pump. Ideally I'd be able to break of the module batteries for this purpose, but I'm not sure if only having one battery for starting is a good idea for my 7.3 L Powerstoke.
So now I'm thinking of adding another battery bank for the deep cycle purposes. I was thinking of changing the module power solenoid to a BlueSea automatic charging relay, and wiring in the new batteries just after that. I'm not exactly sure which model of ACR to get.
Later I'll add solar and wire the charge controller after the ACR as well. The idea would be to run all the module stuff off the deep cycles and those batteries would charge along with the starting batteries off the alternator or shore power, and off the solar power the rest of the time.
Am I correct in assuming I need the three existing batteries for starting purposes? Is placing the ACR in place of the solenoid the way to do it? Is there a better way to do it? Any other problems with or improvemnets on this plan?
Thanks in advance for any assistance!
Jon
Jon
