First Gen (2001) Tundra Parts
smokeysevin
Re-redoing things the third time
I have the following I have taking up space in the garage that I need to get rid of. Make me a reasonable offer and cover shipping or pickup and they are yours. All items located in Houston Texas
OEM 2000? 7.5" RR 4runner 4.10 Front gearset and carrier
OEM 2001 Toyota Tundra V8 Transfer Case: Does not have the actuator on it, used, unknown miles
OEM 2001 Toyota Tundra V8 Transfer Case Adapter: good condition, never ended up using it.
OEM 2004 Tundra 2WD A340 Trans and torque converter: Used with 150k? miles, pulled from my truck when I started the 4wd swap. Shifted well, clean fluid.
OEM Toyota Chrome Rear Bumper and Supports: Good condition, surface rust on inner face, no dents, no chips/scratches in chrome, no pads.
I also have 2 new first gen tacoma aftermarket inner cv assemblies that fit oe axles.
Sean
smokeysevin
Considering Selling my Deaver G57 Springs if the price is right, I recently rebuilt them with new pads, lube, and bushings from deaver. They have less than 3k miles on them since the refresh.
Sean
smokeysevin
Switch components and panel. Switches are red illumnated, the panel is laid out for a circuit breaker on each switch. Each of the larger holes are are sized for blue seas systems usb, cigarette lighters, and volt meters with a breaker spot for each pair and one for the whole panel.
Make an offer
Sean
Sent from my LM-G710 using Tapatalk
Sean
Can you tell me more about the springs? How many leafs in each pack?
They are standard g57s, I think 11 leaf pack.
Sean
Sorry, not that familiar with them. I know that Deaver is one of the only companies that makes leaf packs for 1st gens. How many miles on them before you did the refresh?
smokeysevin
No clue on total miles, I got them used a few years ago. My truck is an occasional weekend driver so I haven't put all that many miles on them.
I loved these springs but I am preparing to do a link setup at some point.
Something to keep in mind is that they ride great but you need a good shock on them and they are pretty soft.
Sean
Sean
Got it. Can you post some pictures of them?
zhukoveli
