2001 Tacoma 4x4, manual, v6, TRD
Rrmay
2001 Ext. Cab V6 Manual-5 speed 4x4 TRD(locking diff) for sale. 174k miles.
2 inch old man emu lift, great tires.
Zero rust(Tx truck) $8,500
Things done in the last 4k miles(everything is oem with receipts.
Water pump-aisin
Timing belt
Thermostat
Idler pulley, ac pulley
All 3 v drive belts
Radiator
Front 02 sensor- denso
Clutch, slave, master(all aisin)
Redline synthetic(diffs, transfer case, gear box)
Spicer carrier bearing
Spark plugs and wires
Valve cover gaskets
Cleaned maf and throttle body
Greased driveshaft
New fuel cap.
Replaced all aged vacuum lines
Drives perfect. 512-foursixsix-320three Stephenville, Tx
Ancientsojourners
