Fridge Straps?
Etoimos
I know just about any type of strap will do and for the past two years I've just been using para-cord to tie down the one in the back of the Jeep. However, we recently got an off road trailer that has a fridge slider in it and I was wondering if anyone had found a setup that they really liked.. or disliked? If it matters, I have Dometic fridges.
The_Hoff
I just use a ratchet strap in the back of the discovery. Stays in place even on hardcore trails.
Ovrlnd Rd
I have and ARB and purchased their strap kit. It has hooks that fit over the fridge handles and holds it tight. I actually built a platform so it would sit flat on the rear floor of my Titan and bolted the straps to angle iron brackets.
jgaz
I ordered four of these in what ever length I needed.
plh
Harbor Freight typically has a bazillion choices. I found some there that work great for my application.
nwoods
Tembo Tusk makes a very specific fridge strap. I have no idea what they cost, as i won mine at a raffle, but they work well!
(I also have an ARB 50qt)
theksmith
this set of $18 straps from Amazon worked out really well with my latest slide, ended up only needing 2 of the 4: https://amzn.to/38IjUrL
lsMqafh5kLyq-femSS7EH14H7bUG0LpphxExXWgrRe4kvcjiZilUEvrS5_nNtuHz2P0HD872d4oYMJX0khF7LNMht7ru_cmPlmbK9fBD44vTwBI8xI30nxHdxjxsrhRK7Zosw3cQkAHJbwy4LS9RRJO-gs86UoBVfRhWCNOrtgNgnIF8yiYwBkOsW8DdZqAN9CWsRhL3rcTX-d0Ikv0NPnYdN9OCOAn6idHqTmvO2DiUbRn9Yj6rIlhjDUKROLaqgAJzYHXUtZHpK8UpPPirs7Di5Cd1qJsp_PDMPd1B-MiHOXzWJ7bztT2B88ilp3kRqDscW5wtl-O5gMV87Z-W9zuuwHLc1MApc9SszkHh5Ty3fRrT64yhA2f37_triN_4XmiDuQWaKdSpyzRarsSkahmm1jZkAUHgVMnd0NaOR3rP6T6Wh6vVr7iThFg0WEcNCK0ubkKk3pHOuH6I9zaPx8rTa6VnWOxNKFUs8Z92m4wyqjr3sA1R7fmLHSsB4z7br4PYL0hSH42pLMnXwzwHk2i0ZCh2op2i1jbV4DRA1F54XaPvSGIUNROT9AeFFbUzHs3WrbpM-kw_BQ9-tY-x5aLlVdx9Yfg4RcHtGmho6k3Zwge7qVRzTMeuThVTgamjPSmcIGPA2h6zC6B4-8JmxVWlMHo5-CmEwL0OPWnRYonYi6dlOj5Iy53lQ7yEX4FeXg7NI-X3NHToia9721mppyQhI39f8nl21snjfe-ZJp34z7RCaw=w1707-h854-no
NJD-CVhCC5_618aLDd7JMhZfRwLg-L7HV-aDiMtWVBToKztCamQycC4gfEjcpqvP5dVUXkWyfJmyapvzav0Jq0RHu21j42kaauEdzQISDyH9FUNS8dkJ5cm1QJO6Fdij7wQDRBxE-tLkOkZvFV9FvAIJuN2oUevUy1S8Gs5Te4aydixFI09nJ0FJogUYdM_gtUX0Ur0J9IZXZmsTKOv9U1W5bx2hfyF3NhBpg3nUl6FFpSanvcyRkAA6RfSpF4cOnlQ0FdI6shJuw_dhFwxF5fl--ijNrCzq4eK1iz1Use6DxO2DckUSPuWsHD_A2XAnjJME5aqvBP9FPy6W3xDRqlD8cg1Z7FiITGOITJX1YO-GBNjokrb16l94sLksy8kYrt17g9x9HQkz2GdaNSrYbFw2l6ysJ_dGLLIZwz5pQ02KbXD0Ya_oJ51qWQOIfKSz0sGsRz4kmkacu39-wYZ6xbQ6o1rqOhsbOJEeZOkEutsN35jG3zU6f6l1U63tb-aH-qkTIoYPYGVpoIuYLsMnTn1hQVLY8WH-sdvP36gD15It7jWgwUG9C8FRBHr34UQOQmdw7IcTTIGbjN-KCxIROWX3HBeQWyz-ZENTYHOIMnL-h-uEBGnhUUbGienC0NikPeoRkNDPSeFqJ36mVBZ8aH9g7i8VOsvtVtK1SErYvVfrjtcj0nxO0sGkfauG_GinxPM39rLMTFpN9R3Z-laEw8Xq9bv3kAC7iLdZV5PuD-CVVoCeYQ=w1707-h854-no
1leglance
Rollercam straps. Been using them since they were intro'd. Nothing else in the cam strap and/or ratchet strap world compares for tightness and compact form factor. https://www.rollercam.com
I also love the Rollercam.....since I bought some at Overland Expo I have beat the crap out of them with no problems. You can tighten with 1 hand and release just as easily, never had one loosen on crazy washboard.
Cheap as almost any other strap and the end loops are my fav....but I also use the straight ones in some applications.
JPOVS
Raingler Nets has fridge tie down straps that look really nice:
Due to those looking like they wouldn't work for my setup, I was going to go with some of there more simpler straps:
Etoimos
Thanks for all of the replies everyone. I know there was more out there just plain old straps.
I've not heard of these, but they do look interesting. I did not see it on their site, but how wide is the strap? It looks about an inch wide or so.
spressomon
Yes, the straps are 1" wide.
Superduty
Another vote for Rollercam.
I use the ARB straps with my ARB fridge. But if I was buying straps i would go with ROLLERCAM. I bought a few of them a while back and love them.
oskarf150
