For Sale: 4X4 Mercedes Benz 1017A Overlander truck
-suitable for dirt roads and off road with connectable 4 x4 drive
-The truck has uncomplicated technology, so it can be easily serviced anywhere.
-simple and reliable technology, low-cost and family friendly expedition mobile to discover the world in all different angles.
- good supply of spare parts by Mercedes Benz
-German and chilenian registration and papers. Chile technical test up to date.
Specifications chassis:
MB 1017 A 4x4 : manufactured 1984, 280 000 km, (former German Federal Armed Forces), leaf suspension, with hydraulic tilt cab engine: inline six-cylinder 5.9 l with turbocharger
In the last time we did a lot of service work: at 260 ´km engine completely overhauled, all seals are new, parts of the injection pump were renewed and serviced. Following items we renewed : alternator, clutch, oil pump for engine, starter, cooler steering rod and track rod.
Total load: equipped ca. 10 T. Maximum load allowed 12 T.
Battery capacity: 2 x 90Ah starter batteries power
Power: 125 kW (170 HP)
Top speed: 90 km / h
Transmission: 5 speed manual transmission
Drive: rear axle drive with differential lock and selectable four-wheel drive
Diesel consumption: ca. 21 l /100km
Diesel capacity in two separated tanks 650 liters
Dimensions vehicle: length / width / height 7,40m x 2,50m x 3,65m
Cabin dimensions: Length/width/height 5, 05 m x 2, 50 m x 2, 27 m
Cabin storage on a 4-point-bearing intermediate frame seats
Tires: Michelin XZL 365 85 R20
Two seats in the cabin, burglary protection at both cabin windows
Store boxes outside: driver´s side behind pressure tank 100 x 64 x 66cm , driver´s side behind rear wheel: 56 x 42 x 62cm , nearside: 58 x 45 x 51cm, roof stand with different store boxes
Spare wheel: crane and basic structure for work at backside
Spare parts for the truck: 1 generator, 2 brake cylinders, Thermostats foe engine, engine seal sets, many tubes and parts of the cooling system, etc.) and for the living space( tank for the toilet and other parts, lamps, windows) are included.
Holder for gas bottles: placed outside for 3 x 10 kg gas bottles
Freshwater: 500 liters in 2 separate PE-tanks. Shurflow water pump system with sensor pump. Hot and cold water in the shower and in the kitchen sink.
Outside shower with hot and cold water.
Greywater: 90 l PE-Tank, to empty from the outside.
Camper
Kitchen: kitchen worktop marble 78 x 52 cm with house style sink and mixer tap. Refrigerator 12 V 70 l compressor König-Sonne , SMEV 3 flame burner gas stove and gas oven, kitchen unit with soft drawer system of 7 cupboards below and 4 above the working space.
2 comfortable big seats 110 cm with table 76 X 110 cm. Extra space.
Bathroom: 20 l Thetfort cassette toilet. Shower 70 x 65 cm, big toilet cabinet
Water heating system: Truma Gas water heater 20 l, 12 V and Seaward F 660, 27 liters, 220 V with motor heat exchanger
Heating: Truma E4000 gas heating 12 Volts
Beds: two single beds 0,90 x 2,00m
Lighting: 5 energy-saving lamps, multi-colored LED lamps, storage space lighting
Windows: 5 Seitz S 4 windows with blinds and mosquito blinds, with burglary protection made of stainless steel on each window. One large panorama window beside the eating table 130 x 85 cm
Isolation: 60mm Gfk-sandwich construction cold-bridge free built. Connection door living space to driver cabin 62 x 80 cm
Power
Battery capacity: 3 - 210Ah AGM Batteries (2018) for 12 Volts on bord tension:
Inverter. Victron 500 watts (2019) for 220 V. Waeco Inverter 1500 W (2019)
Battery charger: Victron Centaur 12V, 60 Ampere, 3 exits for charging working tension 90-265 VAC - 50/60 Hz
Solarsystem: 5x 200 Wp monocrystalline photovoltaic modules (installed between 2015 and 2017) on rooftop.
Battery solar controller: Victron MPPT 100/ 50 A (2017)
new asking price : $55.000. (US DOLAR). Open for reasonable offers.
1cambo
Camper
Power
This is a very cool rig, I am wanting one and this price is awesome too!
However I am not yet in a position to purchase. GLWS!
