Wilco Hitchgate Offset - $850
Coastie24
Hello all. Selling my Wilco Hitchgate Offset that swings to the passenger side (helpful because it is away from traffic!). It is two years old, was used for a cross country adventure and has been in the garage since. Needs a new home so I can fund either my RTT, decked system or custom rear bumper with dual swing outs. Loved this swing out but currently not running two spares and was able to get my 35 inch tire under the truck after removing the exhaust heat shield. My loss is your gain!
Full disclosure the lock pin did get bent when someone tried opening it without realizing they needed to pull the pin up so it would swing freely. When that pin bent it did gouge the metal a bit but was treated and painted. Pictures on request. I was able to bend the pin back mostly and it works as it should. Comes with all original mounting hardware.
Here is the link to Wilco's website: https://wilcooffroad.com/shop/hitchgate-offset/
Located in Cape Cod, MA. Can deliver within reason... will be traveling to North Carolina for work at the beginning of February and should be able to meet someone along I-95 or Route 13 down through DE and VA. Also travel up into NH most weekends right now and could possibly meet there as well.
Asking $850.
68camaro
Any River...Any Place
Hi, I am in Richmond and I-95 runs straight thru on way to NC. I need the right sided one while yours is left. Do you know if you can move the tire carrier from one side to the other without cutting and welding?
Coastie24
Unfortunately you can't switch it without cutting and welding as far as I can tell.
ct73
Is there any possible way to ship this? Happy to pay, within reason. Thanks!
Chris
DFWSFO
