rruff
Correct me if I'm wrong y'all, but it's different if we're talking Fuso/Isuzu, or Unimog, vs modern domestic pickup, yes?
Pretty sure the frame on your truck is designed to flex. Like this one:
	Actually your chassis-cab might be even more flexy. It's possible that the 4WC can accommodate this, but it's something to check on.
Unsure about fords, but ram chassis cabs are C channel and their pickups are fully boxed. Seems counter intuitive
I think it has more to do with payload. A boxed frame (torisonally stiff) has become common for 1/2ton and maybe some 3/4ton, but the higher the load is the tougher it is to make a frame that is sufficiently stiff *and* strong enough to handle the load. So they are designed to let the frame flex so the wheels stay on the ground when you get crossed up.
