terminals & crimper recommendation sought
s.e.charles
I know there's a gazillion wiring threads, but i'm hoping for a more concise answer than "search" will net.
to wit:
from Amazon, is there a brand & model terminal crimper that will get me through most wiring scenarios?
and, 2-part question, is there a brand of terminals (no heat shrink needed) which is better than the others?
thanks
DaveInDenver
Middle Income Semi-Redneck
Need to narrow it down a bit, what sorts of terminals? Small gauge, battery terminals, etc. Does it have to be from Amazon? Do you have a strict budget in mind or is this purely a quality vs value question?
If we're talking about typical general purpose chassis wiring you're safe going with an Ideal frame and dies to match whatever you're doing. Not the cheapest but shouldn't be to awful expensive. I think the frame I have was about $50 but a set of Ideal dies is going probably be $40 each. The thing here is with the crimper frame you could probably skimp and the knock-offs are OK but the difference between good and bad dies is obvious and it's hard to say without seeing a set up close and using them.
Generally for terminals the best general use are brands like TE (Tyco), Molex, 3M, Amphenol, Panduit.
shade
to wit:
thanks
Dave has some pertinent questions, but here's a good place for general answers:
The modular crimper he sells is good, and the dies may work for your needs. RC has some terminal type & brand recommendations in that article, too.
s.e.charles
Need to narrow it down a bit, what sorts of terminals = spade m & f & 3-way spade? Small gauge = YES (only) , battery terminals, etc. Does it have to be from Amazon = YES (only) ? Do you have a strict budget in mind or is this purely a quality vs value question = YES (only) ?
… for terminals the best general use are brands like TE (Tyco), Molex, 3M, Amphenol, Panduit. got it; thanks
I guess I should 'fess up and admit it's for a Lionel model railroad layout i'm building for a friend!
john61ct
Also the battery cable post, everything at that site is good.
Amazon has huge gaps once you get into specialist gear.
genuinedealz.com for custom harnesses if you can't justify buying the right tools and supplies.
Some places let you use the tools if you buy your supplies there.
SquirrelZ
"I guess I should 'fess up and admit it's for a Lionel model railroad layout i'm building for a friend!"
OK, its way off topic and some might consider it off color humor, but you brought up toy trains.... This just happens to be one of my favorite jokes.
How are toy trains like women's breasts?
Both were intended for small children but adult men seem to get the most pleasure out of them.
And back on topic....
I bought this crimper for wiring a camper van. The quality is OK but I did have one crimp that was a bit loose. It was easily resolved by wrapping the lug in a few turns of electrical wire and recrimping.
s.e.charles
Are you only considering products sourced from Amazon?
If so, why?
quick & easy.
this is one of those projects I liken to ordering a steak in a restaurant: I simply want to have dinner. there is no added value to the wait-person standing there and explain all the parts of a cow.
s.e.charles
it's the ride through the tunnel i'm most looking forward.
shade
quick & easy.
As John mentioned, Amazon can be a spotty source for such things. It's definitely not always a WYSIWYG experience.
As long as the correct dies are available, you'll have no problems with this crimper, and SailboatOwners appears to have the terminal types you want.
If you use that tool and those terminals properly, I doubt you'll have a problem with any connections, whether on a model railroad, offroad vehicle, or boat. I wouldn't say the same of the Amazon route, but that may work out ok, too. Maybe you'll get the steak that wasn't dropped on the floor.
Or maybe you will.
john61ct
quick & easy.
Problem is you're not likely to find a good steak going to McD's
shade
I have a friend that loves McRibs. Seriously.
He'd also buy a 200 pc jar of ring terminals for $5, use the free crimper for installation, and wonder why things went wonky a few months later.
luthj
Engineer In Residence
I bought some of these to put in my spares box. These are not heat shrink, but work okay. I preffer heat shrink units as they are more secure though. They are definitely lighter duty. If I was doing high power or mission critical applications, I would spring for name brand like AMP or Molex etc.
I have had this crimper for about 6 years. Adjustable release for repeatable crimps. The dies are for insulated terminals, and should do 18 to 10 AWG.
project13support
