ski_bike_camp
Ski_Bike_Camp
I fell off the grid a little. Too busy I guess. But, I have been busy finishing some things on the rig in preparation for a tour of SW Colorado ski resorts next week. 5 resorts, 5 days and 660 miles. We are going to live like gypsies from one parking lot to another.
So what's new ...
Titan XL Fuel Tank:
I had to drop the Titan XL fuel tank because the fuel gauge wasn't reading correctly and I almost ran out twice. Oops! The issue was the OEM fuel sender gets used for only the fuel level when the Titan tank is installed and the fuel pick is via a FASS sump and FASS fuel pump/filter. If the OEM sender is isn't rotated just right in the tank, it interferes with the FASS fuel sump hose and therefore gets stuck. Lots of fiddling and getting the position just right, problem solved.
Espar Heater Deisel Fuel Pickup:
I used a FASS pickup, which is a 5/8" tube and it didn't do far enough down into the tank. Basically if the tank was less than half full the pick-up tube emptied and it being such a large diameter tube the little Bosch pump couldn't overcome the airlock to feed the Espar furnace. I ordered a longer tube from FASS and it now sits approx 2" off the bottom of the tank which is roughly a 7-10 gallon reserve. I didn't want the heater to run the truck out of fuel
A heater data point, I ran the heater in Breckenridge for 3 days straight. It was going down to approx 4F overnight. I was able to keep the camper at 74F steady and used approx 1.5gal of deisel per day. The furnace underneath is a Espar D5 Hydronic with two air handlers and a hot water exchanger inside the camper. It is all part of a Rixen System.
Cubbies:
The covers for the cubby holes arrived for the back wall storage. They are sunbrella. A note on this ... I really tried hard not to create an sealed spaces where mositure could remain and eventually mold develop. The cloth covers allow everything to breath but keeps things from flying out of the cubby as I go down the road.
Redarc BCBD1240D:
I now have the house batteries connected to the truck for charging as I run the engine. I opted for a Redarc unit from Australia. I ordered in the US from eTrailer.com. The unit basically simplifies and improves the charging of the LiFEP04 batteries.
I have attached some new pictures of the interior.
			So what's new ...
Titan XL Fuel Tank:
Cubbies:
Redarc BCBD1240D:
