s.e.charles
You still haven't provided the details on what the application is.
Or was that model RR bit serious?
yes; serious. the fellow was given trains when he was young and now at 72, he is allowing himself to enjoy them.
Installing terminals doesn't always involve 1 wire - 1 terminal. Many times I'll have 2-#18 into #14 terminal or 2-#14 into #10 terminal.
I have a couple ratcheting crimpers but I grab the Klien insul / non inusl crimpers 95% of the time and carry them when traveling. Had them for years.
Couple sets of these for wire stripping. I'll use the next size up so the copper is not damaged i.e. 12ga hole for 14ga wire
A set of flush cutters that will trim zaps straps off flush so no one gets cut by the sharp end of a zap stap.
I bought a pair of stippers similar quality to those and couldn't figure out what I was doing wrong. The painted over cutting edges where what finally tipped me off.Fwiw, these are clown approved. Steer clear.
A legitimate ExPo guy would already know that, of course.Everybody knows already, solid and stranded conductor are different diameters for each gauge.
Its little known, This Klein stripper yellow grips indicate its for solid conductor. Were it red, thats for stranded.
Similar strippers from Ideal, list solid and stranded gauges at each hole.
… one good crimper can cost more than a dozen train sets![]()
Similar strippers from Ideal, lists the different solid and stranded gauges at each hole.
