Hi Guys,
I've started a new build on a 2014 G550 with 45k original CA miles.
Build list:
Thor G10 17" wheels custom powder coated flat black - Installed
BFG ko2 in 285/70-r17 - Installed
Ohlins shocks for up to 3" lift - on order
ORC Locker and brake lines - installing when the Ohlins come in
Caster correction bushings for ~50mm lift - In route from Germany
VTS fender protectors - Installed
VTS tire carrier cover on the 18" OE spare. Using a similar diameter BFG ko2 for spare.
40mm spring spacer with OE springs - Installed (I also have a set of nearly new Thor springs off my 05 G500 I haven't decided to run)
OE mudflaps - on order
FrontRunner full rack and fairing - in the living room currently. The truck wont fit in the garage anymore once its installed and I've still got suspension work to do
Build list:
