Hodakaguy's 4x4 Sprinter Build
Hodakaguy
Continued from above....
Getting ready to install the fan unit
And installed. I'm happy with the way they turned out, nice and clean. Having the two fans when camping will really be awesome!
More to come as time allows.....
Hodakaguy
Arjan
Fossil Overlander
That looks very, very nice !
Well done and hopefully 100 % waterproof.
Are you considering some bracing / bars to protect them from overhanging branches ?
Hodakaguy
Haven't been working on the van for a while but it's time to get going on this project again.
First up is to clean up a bit of wiring. There are two pig tails of wiring hanging down from the ceiling that used to go to the roof top AC, I'll remove them and tie the stubs out of the way to the main harness. Also note that I filled the ceiling cross members with low expansion foam since there is no way to pull in insulation through these beams.
Wires shortened and staggered, marine heat shrink applied to ends.
Bundled up to the harness and now out of the way.
Next up.....Insulation. We will be installing 3M Thinsulate SM600L, this is both a thermal and acoustic insulation that is hydrophobic and won't adsorb moisture. My friend ordered a large builders roll and we purchased ours from his roll.
Getting ready to start cutting...
My wife is doing an awesome job cutting and fitting the insulation!
I'll be building the interior out with all new panels (I'll be reusing the factory window trim for a finished look) and will be running L-track along the walls and ceiling similar to the Adventure Wagon interior kits. Part of running the L-track on the ceiling is building braces/supports that will go behind the L-track and greatly increase it's load capacity.
The Adventure Wagon interior kits come with really nice support brackets, but they start at $11K which is a little rich for my blood so I'll be fabricating my own brackets. I Picked up some C-channel and flat bar to fabricate the supports with, this will be rock solid when finished.
Cutting mounting tabs.
Tabs cut and mounting holes being marked and drilled.
First brace ready to test fit in place.
Looks like it's going to fit perfect. The L-track will be bolted into the roof supports via Plus Nuts then will be bolted into the braces as well for extra support.
More to come.....
Hodakaguy
Binky
Where did you get the piston?
I really wish I could stop in the middle of a project to take pictures!
John
Arjan
Fossil Overlander
Good so see you moving again with this !
Mrs. seems to be enjoying herself..
What made you decide to leave that old wiring for the A/C in and not removing them, if you don't mind my asking ?
Hodakaguy
The AC wiring is wrapped with the main harness and would be a major job to remove without any additional benefit, best just to abandon in place.
Hodakaguy
Hodakaguy
Arjan
Fossil Overlander
Thanks - makes a lot of sense to leave it in.
Interesting it though that it seems MB puts in those wires, regardless of A/C being fitted or not. Unlike many others that'll run an additional loom.
Those "Plus Nuts" are very, very interesting as indeed they seem to have a much better "hold" than the other type.
Very nice build !
Hodakaguy
This morning we cut the final piece to finish out the horizontal run above the drivers side windows. An aluminum blade on a chop or miter saw works perfectly, makes a nice clean cut that's perfectly square.
I marked the hole locations and here we're installing the plus nuts.
And installed. I'll be counter sinking the holes and installing flush bolts later in the build.
Finishing the trimming of the passenger side rear window plastic.
Marking and drilling the holes in the passenger side window L-track.
Next I used the drilled L-track as a guide to transfer the hole locations to the van. Used the same 1/4" bit to just barely make a mark on the van wall then remove the L-track and use a punch and 3 drill bits to step the hole up to size for the plus nut. My dad is giving me a hand here, it's great to have an extra set of hands!
Using a shot vac when drilling the holes really saves a lot of mess and clean up work.
Plus nut's installed and L-track mounted.
Continued Below....
Hodakaguy
To install the two forward pieces of L-track on the ceiling I'll need to fabricate the supports at this time since there is only 1 bolt that will go into the roof rib, the rest of the bolts will be in the support braces. Here I'm starting to fabricate the brace using the same C-channel.
Cutting a notch on the ends to allow the mounting tabs to angle back a bit to match the angle of the roof beams. Using my favorite shop tool....my Portaband.
Getting ready to weld on the mounting tabs, the tabs are welded out on both sides.
Installing the Plus Nuts and bolting up the support.
Once bolted into place I transferred the hole locations to the brace and pulled it off once more to drill the holes and install the Plus Nuts into the brace.
And All bolted into place in the van. This setup is going to be super strong once all the braces are installed! The two pieces of L-track came out nice and tight.
At this point I stopped taking a lot of pictures as we worked to get the drivers side finished before daylight faded. On the drivers side brace I decided to angle the ends of the mounting tabs upwards a bit to ensure they stay out of the way.
Drivers side mounted up.
And ceiling completed for now. The fish-eye lens on the phone makes the tracks look like they are bent a bit in the photo.
More to come....
Hodakaguy
jgaz
Thanks for the tip on the plus nuts.
I’ve installed literally dozens of Rivet Nuts and have never heard of them.
Just another reason I follow all your builds.
BTW: I love the piston that you are using for a vise stand.
Definitely the coolest stand I‘ve seen.
Arjan
Fossil Overlander
More than cool......
Love that kind of machinery !
I play with trains for a living and we had some very interesting toys....
Petersmithinak
