"Grapes of Wrath" Excursion build
nitro_rat
Lunchbox Lockers
Got an order from Rock Auto in today. Dorman front bump stops, front sway bar end links, and some Energy Suspension poly stops that were listed for the rear.
I didn't work on the back yet. The way the Energy Suspension rear stops were listed I wasn't sure if they were for the spring "traction bar" location or for the frame to axle position. The instructions were kind vague and mentioned requiring the installation of an "included washer" that wasn't included. They are too tall for the "traction bar" position. I may try to send them back.
On to the front. When you're at stock ride height and the rubber is missing from the bump stop, a few things happen. The most immediately noticeable thing is the hard bottom out on even "mild" hits. More concerning is what happens during that "hit."
The front bolt on each side that secures the bump stop hits the front shock mount/u-bolt area of the front axle and it deforms the head of the bolt. The bolt head becomes the new stop. Also the front sway bar end links over travel and in my case, both lower bushings were shot and on the passenger side the lower bolt was quite bent.
In order to remove the upper sway bar end link bolt on the passenger side, I had to remove the nut, push the bolt back until it hit the exhaust and cut it with a hack saw. It's a 10mm 10.9 bolt so it's quite hard and difficult to cut. I would recommend a power tool if you have access to one. If your truck doesn't have the V10 YMMV. Once the offending bolt is removed it is a simple matter to insert its replacement from the outside with the nut on the inside.
The difference in handling, NVH, and ride quality is astounding. The truck is very smooth and composed in my rough driveway which previously caused a bottom out at least once every time. Money well spent!
If you're keeping score, the tab at Rock Auto was about 88 bucks. I still need to decide if I'm going to use the poly stops for the rear. At this point I'm leaning towards keeping it all stock as it seems like it's working pretty well for me so far.
My trip to Colorado in February should reveal any weak spots, I'm thinking I'm going to want front and rear lockers and 4.56 gears to round out the package. I'll probably try to sort out some cosmetics before addressing the axles as they both seem to be in pretty good shape and not leaking at this point!
nitro_rat
Lunchbox Lockers
All that was left of the front bump stops:
The offending sway bar end link:
The Dorman bump stop installed:
I don't know why this one will only load upside down?
nitro_rat
Lunchbox Lockers
Today I scored a hood and front fenders from a 2000 Eddie Bauer Ex for $90!
My plan is to cut the bottom of my fenders where they're roached and weld on the bottoms of these fenders. The repair will be behind the cladding so it won't be noticeable and all my paint will still match!
Headed to work for a week or so tonight so no more progress until I get back.
nitro_rat
Lunchbox Lockers
I've been slowly plugging away at it. Got the winch mounted and the beat up bumper cobbled back together. Crimped new ends on the factory battery cables to use with mil-spec terminals. Tossed on a Harbor Freight light bar wired to the factory fog light switch.
The winch has sagged the front end between 1/2 and 5/8 of an inch depending on how I'm parked. The weight has significantly increased bottom out events. I'll be looking for a spring upgrade soon!
nitro_rat
Lunchbox Lockers
Mounted my farm jack on the front bumper, I don't like having it inside.
My dash "power point" socket was busted so I replaced it with this USB port I found in my electrical junk box.
Mounted a Stream Light charger in the console. Put together a first aid/emergency kit to go in there too.
Fire extinguisher went in the passenger floor, clears the seats full travel.
Cut a piece of 3/16" plate to fence in my recovery gear under the back seat. Don't need that stuff flailing about the cabin in the event of an accident!
It was actually pretty tricky to get the plate to clear the full travel of the seat when it's folded down!
nitro_rat
Lunchbox Lockers
Shoot you are right in my stomping grounds. Great pics.
Definitely coming back for more exploring. I need to get my camping kit sorted!
Love your K5, I've also been following Larry for years. My previous rig was an '84 K20 Suburban that I finally retired at almost a million miles!
zoomad75
K5 Camper guy
I appreciate the love for the K5. Next time you are headed this way let me know. If you need any info on where to go I can help.
dnovotny
Here's a picture from my 2000 showing the weather stripping if that helps.
nitro_rat
Lunchbox Lockers
Not much going on with the Ex until today. I've just been daily driving it and keeping the oil changed.
Back in October of last year I picked up a multi process welder from Harbor Freight. I recently got a bottle of mix gas so I broke out the MIG. I cut the bottom of the driver side fender off and spliced in the bottom of the donor fender I picked up a while back. I was able to get the plastic flare mounted and everything looks much better!
I still need to mount the new flare on the other flare but I won't need to do any body work on the other side...
before
new section welded on and bondo applied
bondo ground down
primed and painted
flare installed!
This thing really drives well and now it's starting to look good too...
nitro_rat
Lunchbox Lockers
Today I attacked the passenger side front flare. The sheet metal damage on that side was minimal so I just replaced the flare with the one from my donor fender.
Now the front bumper is starting to make the rest of the truck look bad...
oskarf150
