Relay Box Question
texasboy893
Has anyone found a high quality relay box? Preferably waterproof.
I'm looking to do a bunch of wiring in my 1985 Bronco and would like to have something that looks oem instead of several relays attached to the fender with self tapping screws.
I prefer the 5 pin Bosch style relays. The tools required to crimp the connectors on aren't an issue.
Thank you for any help.
Sent from my SM-G965U using Tapatalk
Happy Joe
Apprentice Geezer
I have utilized vacant positions in the existing fuse/relay box for some items in the past.
It is a bit of a pain but it can bee done... assuming that your existing box has open positions of the desired type.
Enjoy!
The best one on the market that is sealed is the Eaton ssVEC power distribution modules. They come many varieties, Here are the most common ones.
https://www.waytekwire.com/products?pSearch=ssvec
Take a look at the technical drawings of each one to determine which would be best for you.
I used the 31S-000-0 model because I use low side or ground activated switches. Reason I chose low side switching is because I use the a pwm dimmer for all my interior led lighting and wanted it into dim my switches as well.
Yes that is my 1979 Bronco
texasboy893
Take your pick, then reGooglify by part number.
That's pretty much exactly what I'm looking for. I just wish they used the Bosch 5-pin relay, I've never really liked the micro relays. But I'll make an exception for a box of that quality. Thanks guys!
seth.c96
