Look what came in the mail a raptor steering wheel
ITTOG
Wow, I can't believe they would sell that. To bad they don't sell a kit to make it work easily.
Boatbuilder79
To get the paddle shifters
Trucks are supposed to have manual transmissions but you can’t get an f150 with with a manual transmission anymore.
My truck did come with a column shifter like a truck should and it has buttons on it for manual shifting but it is very awkward-to use.
Then I saw on the interwebs where people were replacing the steering wheels on f150s with raptor wheels and decided I wanted to do that
Todd780
OverCamper
Now if I could only figure out how to add crawl control
Hmmm... That's interesting! So, will the heated steering wheel option work as well? Do you mind sharing how much Wal-mart charges for the wheel?
I'm interested to find out if you get the crawl control feature working. I played with the downhill assent control in mine last summer and it was pretty neat.
Boatbuilder79
I think it needs another module replaced to get the heat to work.
The buttons are supposed to swap over and I found someone online who makes a t harness That will tie the wires from the paddle shifters into the the harness from the column shifter.
The harness should be here tonight along with a new traction control switch.
I can just turn on the hill decent control in forscan but I am pretty sure adding crawl mode will be a project.
On my Jeep I just used a second choke knob to control the throttle bet the f150 is more complicated.
