2wd Vanagon >> Ecotec swap >> 4wd conversion >> camper build
DAV!D
Well it's been awhile since I posted here in this topic. The engine & syncro trans has been in the van for about 5k miles now. It's run flawlessly with zero problems other than a bad starter. This is how the engine sits today and I've had zero issue with the motor mounts. I will likely build a better set up, but likely not until next year when I do the front half of the syncro swap..
I've also been a bit busy doing other things to the van..
I randomly happened to find a beat to hell westy on craigslist which I picked up for $300. I had toyed with the idea of doing a pop top conversion, but figured it would be later down the road.
I cut the roof off the donor van and trimmed it to fit, so the new roof insert would fit on top of the tin top's roof with roughly a 1 inch over lap. This overlap was then glued in place using 3M body panel adhesive. The over lap is completely concealed by the aluminum stripping which holds the factory canvas in place. Meaning you really have to look hard to see it's not a factory roof line.
On the inner lip of the transplanted top, I re-welded all the spot welds in place. The entire process took me about 2 weeks but it was a lot of figuring things out as I went. If I did it again it would probably be a 2 or 3 day job.
Presto the top has been popped.. I bought a new canvas and all new rubber gasket set, but I'm waiting on a replacement skylight before I install it all. I'm now starting to work on the inside cabinets so the van becomes usable as a camper van.
DAV!D
I realize this is old news. Any updates for Vanagon whores like myself??
Yeah, I took the van over the road, lived in it out in Colorado for a bit over a year. The engine swap was completely trouble-free with the exception of the ford OEM fuel pump. I choose that pump because I was on a budget and wanted something I could easily replace without a special order. Well turns out the aftermarket companies changed the design so it no longer has the proper threaded inputs to allow me to use the AN fitting and stainless fuel lines. I found this out of course after the fuel pump I put in it failed. The only option at that time was to hit a upull it junkyard to find another used one.
Other than that the engine was completely trouble-free the entire time I've had it,. Sadly the van has been parked for about 2.5 years now because I went off got my CDL did a year of OTR trucking and then pulled my own numbers to start my own trucking company that I've run a bit over a year now running a hotshot truck. Sadly I've been putting my effort into the hotshot truck and building its replacement so I haven't done anything to the Vanagon since my long road trip it's just been sitting.
I'm hoping to start a full rebuild of it this winter and finally finish off the Syncro front end to make it 4WD finally. I really need to get on the paint and body of it if nothing else because it's starting to look a bit grim from sitting which is why I was looking to do a full tear down and finally rebuild it all right.
