janders
Uhhh... I'd like some words. What is happening here?
First one looks like a racing saw, second is someone didn't know what they were doing at all and got the bar pinched in a terrible way.Uhhh... I'd like some words. What is happening here?
WOW I probably would have just climbed over it but I admire your work ethic. How long did it take?Had a chance to used the Silky Saw while hiking.
Guess about 15 min.WOW I probably would have just climbed over it but I admire your work ethic. How long did it take?
... I admire your work ethic. How long did it take?
Thank you.Guess about 15 min.
Purpose of trail clearing is to limit the impact. Once there's enough blowdown/deadfall blocking a trail people head off in different directions so the trail gets to be 40' wide instead of 4'.
Can't see my self is a million years using a battery operated chainsaw, the things loose too much capacity in just 3-5years. Based on other gadgets I have owned. I use a corded unit with the generator, since the genny is required for battery charging, it isn't too much work clearing a track.
I charge my batteries from my solar while camping. a generator is definitely not required. My makitas also are lasting a good while. Nothing like the old nicads.Can't see my self is a million years using a battery operated chainsaw, the things loose too much capacity in just 3-5years. Based on other gadgets I have owned. I use a corded unit with the generator, since the genny is required for battery charging, it isn't too much work clearing a track.
XL teeth?I've been using the Silky 2000 to clear trails/roads and cut fire wood for 4 years. It is on its 3rd blade.
Spent 6 months considering electric chainsaws and decided to go with a Silky 650.
One of the first things to do with these saws is to Loctite the hinge nut and bolt. View attachment 571789
XL teeth?
I've been looking at Silky for some time.
![20200720_143407[1].jpg 20200720_143407[1].jpg](https://expeditionportal.com/forum/data/attachments/502/502757-0b9959b882d871aa4ff8ba453e5a72a0.jpg)
