LAND ROVER Overland Rig (sold)
Rottenman302
2006 LAND ROVER LR3 SE $22000
Price is negotiable depending on if you remove the tent, fridge, water tank, fuel tank, etc
Runs and Drives like new
Located in Matthews, NC at Performance Rovers
166500 miles
Owned by and worked on by a Certified Land Rover Technician
Outfitted for Overlanding. Perfect bugout vehicle
Upfitted with....
Front Runner Roof Rack
Front Runner Rear Ladder
CVT Summit Series Mt Shasta Orange Roof Top Tent
Mounts for Awning are on the rack already but I moved the awning to my other vehicle
Front Runner 11 gallon water tank on the roof rack w/ spigot
5 gallon Wavian Jerry Can and mount on roof rack
4 cube LED lights mounted to the roof rack as area lighting
42 inch LED light bar on the front of the roof rack
National Luna Dual Battery system with the Controller dash mounted
Dual H8 AGM Batteries
Blue Sea Systems 8 Circuit fuse panel behind the dash that is powered by the secondary battery
Blue Sea Systems 12 Circuit fuse panel in rear that is powered by the secondary battery
Renogy Rover 40amp MPPT Solar Charge Controller w/ bluetooth
Renogy Eclipse 100 watt Solar Panel hood mounted w/ location to plug in extra fold out solar panels up to 520 watts total
NOCO Genius onboard battery charger w/ plug in location in the left front fender
ARB 50 Quart Fridge Freezer custom mounted and hardwired to the secondary battery
ARB onboard air compressor with air fitting mounted in the bumper
2 Blue Sea dual USB charging ports installed in the rear power center(4 ports total)
4 12 volt power outlets installed in the rear power center
Streamlight Strion Flashlight and charging dock mounted in the rear power center
Auxillary overhead lighting installed in the rear cargo area
Kenwood touchscreen stereo with APPLE CARPLAY and ANDROID AUTO
Kicker Amplifier
Upgraded the factory 10 inch woofer to a JL Audio 10 inch woofer(if not wanted the factory woofer can be reinstalled)
Beofeng UV-50X2 50 watt 2 way radio with the antenna mounted on the roof rack
Hood Mounted Shovel
Front and Rear light guards
Lifted with new Cooper S/T MAXX tires
Land Rover Factory Trailer Hitch
REPLACED
Front Air Struts
Has the upgraded AMK Air Compressor
Both Front and Rear Differentials have been replaced and are like new(zero noise)
PolyBush Urethane lower control arm bushings
PolyBush Urethane front and rear sway bar bushings
Water Pump
Radiator
Hoses
Radiator Fan
Thermostat Housing
Rear Drive Shaft
Coolant tank and sensor
Spark Plugs
Transmission pan with Filter
Engine has had Full Synthetic oil and OE Oil Filters since 70000 miles when I bought it
I have Changed the oil every 5000 miles
Drained and filled the transmission, transfer case, and differentials every year since 70k when the diffs where replaced
Engine, Transmission, Transfer Case, and Body Control Modules have been updated to the most up to date software.
garrettjmu
Would you sell just the air compressor? Where'd you mount in bumper? Trying to figure out where to put this on the LR3.
