luthj
Engineer In Residence
I got a line on a local 1 man shop ( its a big steel building in his back yard) who does shafts locally.  Going to get over there when I have some time.
I put about 200 miles on the van, I think I am ready to make adjustments this weekend. Some of the vague steering is bump steer. The body roll causes a bit of counter steer initially. So I need to adjust the steering rack a small mount. Even 1/8" can dramatically effect bumpsteer, so I planned for this.
I need more caster. Maybe another degree or two if possible. I am not sure I have enough camber adjustment to compensate. So I may end up doing a bit of light rework on the UCA spacers. I need about 0.2" of aft shift per degree of caster. This will help with the rubbing I am getting at the front of the wheel well. I need to do some light rework on both front wheel well areas. It should be easy enough to correct in all future versions.
A issue I notice a consistent gear noise. Its almost like loud mud tires, but its only on the drivers side. I believe its the diff gears in the ARB locker. I will connect the front axle disconnect to see if it goes away. Its quite noticeable.
The fox coilovers are great. Combined with the anti dive there is very little nose dive even during heavy braking. Rebound is well controlled. There is a bit of body roll until the sway bar grabs, but its very predictable. The best part is the van just eats speed humps. No bottoming, barely anything transmitted to the cab (comparatively).
I have narrowed my ESP/ABS/ASR activation issue. Its definitely only ASR (anti skid/anti oversteer). Its only at specific speeds (40-55mph). And only on right hand turns. This tells me two things. First, my steering sensor needs calibrated to the left a couple degrees. Second, the tire size difference and 54/55 tone teeth is just enough to make the ASR think the rear wheels are slipping when I am on the throttle.
