Show Me Your Winch Bumpers!!!
93BLAZER
(Front and rear please!)
I will post mine as soon as I finish taking the class "How to post pictures on EXPO, a step by step approach"
In the meantime, for those with an imagination...
I have a full size 1993 Chevy Blazer with a black Warn winch bumper and a Warn M12000 winch. It currently has two KC 6X9 lights attached.
Somebody left a grinder unattended and I ended up trimming it up a bit.
Thanks!
FlyNdrive
Here is my rear winch on a 2007 Toyota FJ Cruiser. (The front is just an ARB Bull Bar.
-Ben
2K54X4
Photobucket makes it easy...otherwise I would never figure it out. :)
spencyg
This Space For Rent
Here is my rear bumper nearing completion.
I'm starting on the front today and I'll post a pic when its done...
Spence
Dragon
This is a custom designed tube bumper that will allow a portable winch to be mounted into the built-in receiver, or it can be inserted into a rear receiver depending on which direction you need a tug from.
I realize this is not an ideal setup once you get into a situation where you need your winch NOW. You certainly don't want to start mounting it at that time, but I did not want all of the weight up front for my daily driver, and I did not want the winch exposed to the elements all year long (lots of road salt here in Chicago)
This is the winch I will be utilizing with it http://www.warn.com/truck/winches/src/xd9i_multimount.shtml
snipecatcher
Homebuilt using schedule 40 pipe. Warn M8000 inside with synthetic line. In this picture I am pulling a half fallen tree out of the ground.
-Dan
sami
My previous rig....
Build pics...
I was going to do brush gaurds but never got around to it..
WyoExplorer
My "Explorer Project" with a homegrown bumper, winch tucked back between frame rails.
With deer deflector and a little paint.
Rear bumper.
Mike
jcbrandon
2007 Dodge Power Wagon, original equipment
Here's the factory original installation on a 2007 Dodge Power Wagon. Winch is a Warn 12,000-pound unit, with thermal overload and low-battery protection, mounted behind the bumper, between the frame rails. I added the air compressor and relocated the license plate.
jordanP13
