2002 Ford Excursion XLT 4x4 V10 (4.30 LSD, SCT Tuner, K&N, SPD Y-Pipe, Ranchos)
Ford_Lifer
118k miles. Very clean. Very very little rust on body panels. Doglegs are good. Frame was POR-15'd. Really solid for a northern truck.
Done in the last 10 days:
• New PowerStop front calipers, Wagner brake pads, MotorCraft Rotors
• New rear calipers, brake pads, rotors
• New front ABS sensor cables
• New custom stainless steel brake lines by Crown (all 5)
• Brake fluid flushed (synthetic)
• Mobil 1 synthetic oil change with Wix synthetic filter
Here's the complete rundown on the truck:
• Five Michelin E-Load tires (4 + spare) installed last summer and rotated religiously
• Always Mobil 1 synthetic oil changes and MC or Wix filters
• Flushed steering fluid with synthetic
• New K&N filters (truck comes with 2 of them, both less than 12 mos old)
• Upgraded Pioneer stereo with video screen and bluetooth for phone integration.
• 4.30 rear differential with V10 engine
• SPD 3.5" high-flow y-pipe
• 5-Star tuner to run on 89 mid-grade fuel
• Lower radiator hose coolant heater installed (for cold Chicago nights)
• Finned aluminum rear differential cover
• New Moog front stabilizer bar bushings
• New cruise control module servo (under hood box with throttle cable attachment)
• Rancho adjustable shocks
• Upgraded Curtis hitch receiver (12k lbs)
• Replaced fuel pump (since replacing hitch required dropping fuel tank)
• Replaced driver's seat foam cushion
• New 2-piece driveshaft and driveshaft boot (to quell vibration)
• New transmission pan gasket, extension housing gaskets, new transmission screen, new transmission fluid
• New PCV valve
• New windshield (stone cracked original)
• Recharged AC refrigerant
• New shift column bushings
• All exhaust manifold bolts replaced as preventive measure
• New serp belt
• New Sears DieHard AGM Battery
• New Rear Roadmaster Suspension system
• Rear Hellwig stabilizer bar
• Concealed X/K radar band detector with dash lights
I have the OEM in-dash stereo and air intake assembly -- they come with the truck.
Photos here: https://www.nikoncatholic.com/Ford-Excursion/i-GprjZGJ
Some of these photos don't show new brake lines, calipers, driveshaft, bushings... I took these photos last summer. I added some shots of the brake lines and calipers and lower radiator hose heater element to the end of the gallery.
Asking price? As much as I can get. ; ) Please don't flame me, but let's start at $19,900. I've got many thousands of dollars sunk into the truck the last 12 months. But I'm open to serious offers.
I live 15 min from both MDW and ORD and can meet you there. Thx.
TXFJ60
• New PCV valve
• New serp belt
These photos don't show new brake lines, driveshaft, bushings... I took these photos last summer.
thanks!
What are you asking for it?
I've got the same rig with the same mods and less miles (115k). In my neck of the woods, you're lucky to get $10k. Not trying to be a jerk, just being honest.
I swapped from 3.73 to 4.30 gears, did the 5Star tuning and y-pipe, 4in lift and running E-rated 285 hwy tires, pristine interior, front tow hitch, bull bar with Hella 7in lights.
Ford_Lifer
I know. An investment that pays returns this truck ain't! Still, there's a buyer at every price. There's just more of them at $10k. ; )
Ford_Lifer
Data point for my X owner friends: I sold my chariot a few weeks back. Didn't get the $18k I had listed it for -- but I came within a few thousand dollars of that figure. Buyer realized all the cost and time it would take to buy a cheaper, less maintained X, and bring it up to the level of my X (ie: exhaust bolts, K&N, Y-pipe, SCT tuner, Roadmaster Active Suspension, etc...). A well-sorted and maintained X will always bring thousands more than Blue Book -- those buyers are out there. It just takes time. : )
Houie
