OBS truck bed dimensions
Chorky
Anyone by any chance know the actual specs for a factory 8' bed for an OBS (9th gen, '97) F series? By my measure its about 76", but for some reason that doesn't seem right. Specs for a flatbed are 80". Trying to figure out what width a rear bumper will need to be, and what the hangover amount might be if a 80" bed is used (as compared to the cab). I realize the factory bed width is, maybe 2-3 inches narrower than the actual spec due to the fender flares?
Also wondering if anyone knows the outside length as well. By measure it's 8' 6"? Just wanting to cross-reference before making any decisions.
NatersXJ6
Hard to believe any pickup with an 8’ bed would only be 76” inside. A sheet of plywood wouldn’t fit with a closed tailgate.
97-98” much more likely, although I do not have one to measure.
IdaSHO
IDACAMPER
76" would be width.
FYI, I have found the sweet spot for Ford full-size SRW trucks is 82" in width.
The cab width at the widest is roughly 78"
The 76" you reference is probably bed rail width, as the bed narrows a bit going up, matching the profile of the cab.
Both of my flatbeds, one being a '96 Powerstroke, and the other being a 2011 Superduty, both beds I built, are 82" wide
Chorky
76" would be width.
Thank you much. My measurement was attempting to get exterior max width of the bed poor mans style. I figured it would be off a tad. So looks like you only have maybe a 2" overhang on either side with your pics then, which I think would be acceptable.
dhuss
