nitro_rat
Lunchbox Lockers
Good to know! I can imagine that the manual transmission combined with the short wheel base rig that’s light in the back would be a bad idea, especially an aggressive one like a Detroit!
I like the eLocker option, especially since I have no plans for onboard air (for an ARB) other then a small portable pump to air tires back up. I’ve had my eye on lower mileage H2 rear axles (most of them won’t part the axles out). Several salvage yards will sell me the whole rear axle for around $400 with lower miles (Around 90k) and I just looked and they still make the service kits for the Eaton e-locker although they are a bit spendy.
I’ve never set up gears before but want to give it a shot. How hard could it be? ?
I know most folks use new R&Ps, but if the gears are in good shape from the donor axle and the parts are compatible, it would be nice to be able to use the H2’s 4.10s with the e-locker... With a GT5 4.10 front diff from the Pick-N-Pull I’d be in business.
I figure that will be a project for next winter though, but it would be good to have my ducks in a row ?
That axle is super easy. You just need a dial indicator to measure backlash, Beam type inch pound torque wrench, and a 0-1" micrometer or accurate vernier caliper.
The AAM axle housings are machined accurately enough that as long as you are using a factory gear set, the pinion shim requred is alwas the same for a given HOUSING. That means whatever shim is in your factory housing will work on whatever other factory pinion you put in that housing!
I would recommend a crush sleeve eliminator kit that uses shims. Just measure the thickness of your crush sleeve and start with .002" more shims. Work down until you get the specified turning torque.
Backlash is set with the big nuts on either side of the carrier. They make a tool for that but you can tap it around with a punch. Set backlash to whatever you measured befpre disassembly.
Easy...
