Go big or go home:
MTVR
Have fun with it and keep posting your project.
Have you done some layouts of the inside of the container ?
Envoyé de mon iPhone en utilisant Tapatalk
Working on it.
The wife and I are trying to come into agreement regarding the length of the container. I'd like to just use a standard 20-foot container, but she wants to use one that has been cut down and rewelded to a shorter length, around 14 feet (the bed is 14 feet long).
MTVR
I am sincerely happy for you getting the rig that you wanted! The point i was trying to make (and obviously not doing a very good job of it) was that if you were planning exploring DEEP in the outback (like in many parts of Baja) and staying "off the grid" for a month plus at a time... You would be better off with a lighter rig that had low range working gears. Preferably low low ones like on Unimogs. Yes, horsepower and torque are wonderful things until you are really stuck... Then it just starts to break things! A calm steady right foot and a really low gear (with low tire pressure and a shovel) if far more likely to get you out of trouble.
And when it doesn't... It's time to go into the hidden vault and pull out the "tractor fund"! From what I've read on this thread sounds like you are mostly going to explore in the USA where there is a good likelihood that you will have Cell service, which is FAR more convenient then down in Baja where there are stretches of hundreds of miles between service and the only way to get help is to walk to a main road and hitchhike to the nearest tractor the be ready to pay the tractors owner hundreds/ or thousands of $$$ to bail you out of trouble. Trust me! I am speaking from experience!
My truck Casa Azul weighs 16,800 dry and usually under 20K wet (too big to get pulled out by a F350) and I keep my tractor fund at about $2800. Enough for a greedy backhoe owner. You will probably need a D8 ($15K ~ $20K) and... Lets not forget the low-boy to get the tractor to your truck!
Best of luck and fun with your new rig.
Well, I may have misunderstood you.
We have a 58:1 crawl ratio, not counting the torque multiplication offered by the automatic transmission's torque converter, which should be good for off road. I also have CTIS that can air the tires WAY down (and bead locks, so that I don't knock the tires off the wheels).
The horsepower and torque is nice on the road, but I have no plans of using it to break stuff off road.
And yes, we're planning on being in the U.S.- we've already done our world travels.
1000arms
... The wife and I are trying to come into agreement regarding the length of the container. I'd like to just use a standard 20-foot container, but she wants to use one that has been cut down and rewelded to a shorter length, around 14 feet (the bed is 14 feet long).
Get a standard 20' container and measure out 14'. Use cardboard boxes to build a full-size model of the interior. She might want to expand to 20'. :)
20' containers are common, easy to replace, a lot less work than cutting a 20' container down to 14', and have approximately 50% more floor space than 14'.
nathane
We are putting a 4.2m (13') box on our mog, should come in at 6500kg fully loaded and be able to access lots of places a beast like this won't, but we have had to accept lots of living space compromises to get this capability.
For your project it feels like overkill to have such a massive truck for such a tiny box, kind of like putting a drag racing engine in a mini to use for shopping trips. Given how your chassis has the capacity for so much more, and the weight and size means you are only really going to relatively developed places why not put something bigger that doesn't require so much compromise from a comfort perspective?
Max out the beast!
nathane
It's funny, I just looked up the empty weight for a 20' container - pretty much the same as our fully built living box including all equipment and fluids (which are 500kg on their own)!
dreadlocks
yeah but how hard is all that extra length off the back going to make traversing switchbacks or other hairpin turns..and then there's leverage, everything behind the rear axle gonna need to be really well built and secured or its gonna go flying like the kids who sit in the very back of the bus.
nathane
Surely looking at the pictures on page 1, if the cab is 12' high the existing bed must be well over 13' long?
nathane
Wow, I hadn't realised it was that short. I guess I'm surprised it's pretty much exactly the same as ours:
MTVR
Very cool, nathane. I see the torsion-free subframe, the pass-through, and the tall roof. We looked for a U2150L/38 or a U2450L/38 to import, but we were not successful.
And we never would have gotten 425 horsepower, 1,550 pound-feet of torque, a 7-speed automatic transmission, ABS, and traction control in any Unimog old enough to legally import (25 years old).
nathane
No, we are some way off that with this 2000 u1550 being one of the last analogue engines and gearboxes. We have 290bhp and 600ish torques with an updated injection system but that's a way off yours. No tc or abs obviously but neither did my Ariel atom so I can live with that ?.
I do think yours is going to be an awesome monster of a truck, really looking forward to seeing the build. It was also much cheaper than a mog by the way at the outset.
MTVR
Well, the tire codes indicate that these are the original tires, from the Summer of 2007. The best price I can find on six unused tires (2014 or newer date codes) is about $3,000. Not insurmountable, but I had hoped that the tires it came with would have been newer. Oh well- we knew that this was one of the risks when we decided to bid on this truck...
dreadlocks
tell me about it, I just checked the dates on my bus tires after pulling it back out of mothballs.. 7/2000, hey they still hold air.. I should replace em, but by the time this thing sees anything more than some low speed test drives between here and some shops those might have aged out too.. might as well hold out until its ready for normal service unless they force me to pull off the spare before then.
quickfarms
Last summer I just retired the last four original tires to my rig and they were dated 1989.
Running old tires is not an issue as long as they are in good condition and you run them fully inflated. Limited tread junking is not a major issue. The old tires get hard.
It is best to run newer soft tires on the steer axle but matched tread and diameters more of an issue in the rear axles.
V45W_Proto2.5
