Beadlock wheels
otiswesty
Regular guy
If its a beadlock, you are unlikely to break the bead from running too wide a tire.
Buy the tire you want and mount it up.
Eric Edwards
They came from military vehicles, so i have no idea.
That is a narrow wheel. I'm pretty sure that the rule of thumb is no more than 3-4 inches wider than the rim. That would limit you to 9.5-10 tops. I think that is around a 255 or 265 wide tire max.
Arvinc
I was hoping to get a 265 75 16 tire on there. That would be slightly over 10" width; perhaps it would be wiser to step down to the 255?
MTVR
Tire manufacturers specify acceptable rim widths, not wheel manufacturers specifying acceptable tire widths.
And I don't know if you're going to find a tire manufacturer that lists 6.5" as an acceptable rim width for a 265/75R16 tire...
Arvinc
Will definitely look this up, i guess i would have to get one with a very strong sidewall.
Arvinc
There are many 235/85R16E tires out there. They will likely be quite happy on the rims you have.
To get an idea of Tire-MFG minimum rim width, you could look through the Duratrac tire sizes https://www.goodyear.com/en-US/tires/wrangler-duratrac/sizes-specs
That should get you started.
Just to reference what Otiswesty said, given that these are beadlocks, would these tire specs be 100% applicable; or could perhaps be used as a baseline and stretch it a bit?
1000arms
Awesome, thanks.
You are welcome.
Many tire places won't mount tires to rims that are out of the MFG's rim range. The warranty, if any, might not be honored, even if a tire place does mount them, or if someone does the mounting himself/herself. Tires can wear unevenly and have poor handling characteristics on-road. It may be illegal depending on where one lives.
Why do you want to run wider tires?
What vehicle will you mount them on?
Will this vehicle be used only off-road, only on-road, or both on-road and off-road?
What is the stock tire size?
MTVR
I see load range "E" tires being mentioned. I don't know that the G-Wagen came with 10-ply tires, but I can tell you that installing 10-ply tires on a light-duty vehicle can seriously degrade the ride quality...
oskarf150
