SOLD: 2015 AT Overland Off Road Teardrop Trailer FOR SALE (near Colorado Springs, CO)
Ausfletch
FOR SALE:
Woodland Park, CO (near Colorado Springs)
DESCRIPTION:
AT Overland Teardrop
Trailing Arm Air Suspension with air springs & shocks​
Structurally reinforced body for off highway travel with marine grade Baltic Birch interior finish, aluminum exterior​
Extensive interior drawer and cabinets including locking drawers​
Locking doors with tinted sliding windows and insect screening​
Fan-tastic roof vent​
High density foam mattress 54' x 75' x 4' thick.​
LED stop/turn/tail lights, LED side markers, LED reverse lights​
Custom front squared off profile for more interior room​
AT Overland Teardrop basement frame storage below mattress​
AM/FM CD Stereo system, Bluetooth, Kenwood KDC-BT958HD​
Custom heavy duty roof basket​
Large powder coated nose box​
Additional tongue storage space​
Tires: Nitto Trail Grappler 285/65R18​
Wheels: Toyota LandCruiser wheels​
*(trailer built with Jeep Wrangler bolt pattern but currently has adapter for LC wheels; also have adapters for F150/Expedition wheels)​
Electric brakes – Electric braked axle upgrade w/10” drums, breakaway kit
Custom stainless steel folding table and rack that doubles as rock guard for teardrop
AT Overland Kitchen
, full slide out
Partner steel stove, 3 locking drawers, 10# propane bracket, two tanks​
Engel Mt-45 (42qt) fridge/freezer on locking slide out tray​
Detachable aluminum sink​
Pass through screen (galley to bedroom)​
Water storage, 19 gal
w/skid plate, elect pump, sprayer outlet, mixer, hose & fittings​
Hot water, Zodi system hot water connection​
Zodi Hotman Extreme Portable shower
Fuel can set
Fiamma F-35 retractable awning
Fiamma 4-wall enclosure for awning w/doors & rafters​
12-volt Power & LED Light package
2 AGM group 31 deep cycle system​
105-amp batteries, 50A coupler​
Battery Charger – Noko Marine Series 20-amp dual charger w/ shore plug​
Interior dome light (red & white), two interior LED shelf backlights (red)​
Two exterior LED porch lights (white), two interior 12-volt outlets,​
Two exterior 12-volt outlets, one kitchen 12-volt outlet, one battery tray​
120v interior outlet w/galley access & circuit breaker​
Solar Charger controller, 10A​
Exterior Solar RV plug, female, 12ga wire​
MaxCoupler multi-axis trailer coupler, 6000# Class III
Propex HS2000 heaterNOT WORKING (see notes)
For a complete build list, invoice, and inventory of all accessories, upgrades, and extras please see the PDF attachment to this ad.
Notes:
Trailer does have minor expected wear from four seasons of use but nothing significant or in need of repair.
The on-board Propex heater is not currently working (I suspect it is a faulty gas regulator and asking price has been adjusted to account for the non-working accessory).
  • 2015 AT Overland Off Road Teardrop For Sale.pdf
Ausfletch
I had a request for some more interior photos so figured I would share with the post...
Enigma5300
Interested in the trailer. Can you explain the hot water system and shower setup. Maybe post a picture of the inside of the box on the front of the trailer tongue and the suspension.
Ausfletch
The hot water system is a Zodi Extreme Shower with a 'nipple' type hook up to the trailer itself. The Zodi can connect to the nipple which then supplies the hot water to the mixer which is controlled by the spray nozzle just like a faucet and sprayer in kitchen. Attached are photos of the sink/sprayer, the hot water connection, and the sprayer/mixer connection. The Zodi is super handy. I actually do not connect it and just use it as a stand alone. I use it a great deal to wash my bikes, spray off the doors, etc. even when I am at home. I even used it to fight a small brush fire on a neighbor's property.
Ausfletch
Here are some photos of the tongue and box exterior and interior. The last one is a photo of the cool custom stainless steel table that doubles as a rock guard for the front of the trailer.
In the exterior photos you can see the trailer tongue, the connections for recharging, shore power, and solar panel connection as well as the electric brake controller. On the inside of the nose box you can see the two huge AGM batteries and the power and solar controllers. There is a ton of the room in the box which which I use to store accessories like extension cord wrench, funnels, gloves, etc. There is also a huge amount of storage between the nose box and the trailer. I will often secure a storage tote or a basket (for firewoood, etc) in this space. You can also see the two five gallon jerry cans and storage. I have an additional red gas can that is part of the package but my truck has 36 gal tank so I prefer the extra water.
Hope this helps.
Ausfletch
The manufacturer did not list a capacity that I can find but I feel pretty darn confident it is more than capable of handling a RTT.
The mounts and rack itself are extremely robust.
I included a close up of the pillars and mounts.
Do you know what capacity of the rack? I would like to put a RTT on there for the kids.
Thanks
Corey
Ausfletch
Ausfletch
Morgan,
Manufacturer listed build weight as 1250 pounds. I am not sure if that included fridge and other peripherals but they wouldn't add a bunch of weight.
It was recently certified as under 2000 pounds as it sits for registration purposes in Colorado recently.
I can tell you I quite literally do not feel it behind my tow vehicle which, admittedly, is a Raptor. :cool:
Ausfletch do you have the known weight of the entire trailer dry? Cheers.
Morgan Weafer
Manufacturer listed build weight as 1250 pounds. I am not sure if that included the fridge and other peripherals but they wouldn't add a bunch of weight. It was recently certified as under 2000 pounds as it sits for registration purposes in Colorado recently. I can tell you I quite literally do not feel it behind my tow vehicle which, admittedly, is a Raptor. :cool:
Thank you for answering my question. It's a beautiful trailer however I don't think my 4 cylinder Jeep will be up to the task at 1200lbs. Cheers.
Goldenbora
