Can someone help me identify this connector.
MiamiC70
Can someone help me identify this connector. I need to get an adapter to connect to my Jackery input which is an 8mm DC, 12V~30V (42W max. ) for 240 and Input: 8mm DC, 12V~30V (100W Max) For 500
Herbie
Rendezvous Conspirator
That looks like a standard 2-pin SAE Bullet Connector
Herbie
This adapter would probably do the job, if 8mm is correct:
or if you need female:
MiamiC70
Yep, that’s it.
thank you
john61ct
aka
universal "2-way flat molded" connectors
Not that great btw
better than ciggie ports though
about the same ampacity
not too many duty cycles
dhuss
