FS Kilby Jeep JK Unlimited Flat Floor Kit
kb7our
Excellent condition. Here is the scoop from the Kilby site:
The JK Rear Floor Kit is designed specifically for the JK Unlimited. Fabricated from heavy 14 gauge steel and finished in texture black powder coat, this flooring is tough! Remove the rear seats and mount the flooring kit to provide a flat surface in the full rear cargo area for maximum interior carrying capabilities. The floor plates are hinged and can be flipped up to increase front cargo depth when needed. Installation is simple and 100% bolt-on.
Installation Notes:
100% bolt-on.
Tie down eyelets shown are not included.
For Unlimited (4 door) models only.
Requires factory rear seat removal.
Here is where you can see some pics from Kilby (mine is not installed so I don't have pics but it's in excellent condition). Page down past half way.
http://www.onboardair.com/tb-jeep-jk.htm
Once the rear seats are out the floor is pretty easy to install. The only negative I found is stuff will slide around on it unless you add tiedowns or if you were to Herculine or Linex that would be a nice touch. Pick up only as the kit is heavy and bulky. Arizona near Phoenix. PM if interested.
$250
Hooter
Has it ever been installed? How often / how used is it? Why are you selling? Do you have to take the carpet out or can you bolt it on right over it? Since the front part is hinged, is it possible to take one off and do either the 60 or 40% rear seat option like Goose Gear’s version? Are there Lready provisions to put tie downs in (I know not included). Finally you mentioned stuff sliding around - did you get the powder coated version or bare metal version? Nice price - I’m definitely interested.
DanoWall
