Overlander Shower
Landy-Lee
Hi guys i hope you are all safe and well.
What shower setups are you all using?
Just a simple solar shower or a full 12V boiler setup?
Thanks Lee
tdferrero
Search bar will answer most of your questions.
4x4tripping
I did use an "Helton Heat Exchanger" - who delivers hot water, if my car engine is running and warm:
Surfy
Dr Gil
Thanks Lee
I've gone from the simple Zodi Extreme setup, to a complex Eccotemp with the pump, back to the Zodi Extreme. Now I know, simple and reliable is better than bells and whistles. I have several posts in some of the threads with my past and current setup you can search for.
Dr Gil
Thanks Lee
You can get away really cheap with a solar shower. Good luck getting that water heated up in the winter or heavy cloud cover. Do you want reliable or cheap?
Peter_n_Margaret
We have a Webasto Thermotop diesel heater.
It heats and circulated glycol and provides hot water, central heating and engine pre heating if required. While driving the engine heats the hot water.
Brilliant.
Cheers,
Peter
OKA196 motorhome
Dr Gil
Brilliant.
Cheers,
Peter
OKA196 motorhome
Could you send a pic of how that device heat water as well as the air?
Peter_n_Margaret
It heats glycol and pumps it around via a heat exchanger in the HWS and via radiators with fans. It can also be plumbed to the engine cooling system.
Google is your friend.
Cheers,
Peter
OKA196 motorhome
krick3tt
I ordered mine on line from Costco (last year, in winter) and it arrived within a week and was very well packed and worked well. Not sure of price now but when I bought mine it was $149 but a week later it went on sale and they credited me the $10 difference on my card. Unfortunately I have not gone anywhere in three months and may not go anywhere for a very long time.
It is also a great place to store 3.5 gallons of water.
sunnyaz
