Best Solar book for expedition vehicle
Madoxen
Hi all, The more i read up on solar the more i realise how little i know.
Can any of you recomend a good current book that would be worth buying or a very good source of infomation. Forums are great but sometimes they can misguide you with misinfomation or incorrect advice.
I realise i am not going to find all my answers in one place but a good foundation in the knoledge would go along way to making better informed decisions.
Any recomendations relevant to solar in 20ft expededition setup would be greatfully recieved.
Thank you
Alloy
Solar isn't so complex that you need a book.
Just review some of the setups on the subforum link below then post what you expect and the very knowledgeable people on this forum will help you.
Madoxen
Hey Alloy, thanks I will continue to read the links :)
You should start with good a understanding basic DC electricity.
Then carefully read ’specs of the equipment you are considering and how it applies to what you want and now know about DC.
From there its easy, and extra credit...
You can recognise which YouTube guys are idiots and which guys share compentent advice.
thank you, while I do have a little knowledge on electrickery I do need to catch up as its been too long since i worked around it in earnest.
Cheers,
Peter
OKA196 motorhome
Thank you Peter & Margaret I will have a look and see if it helps me, thanks again
I learned the most from AM Solar YouTube vids. Best ones out there IMO.
I will look them up thank you for the recommendation
thanks for the advice all
GregSplett
I hear ya on weeding through info on forums. I have subbed this young man on Youtube for a while and love his content here is a link to his book.
Alloy
One of the places to get stuck is researching systems with panel voltage is less than 24V using and PWM controllers. You'll want to look toward houshold systems with MPPT controller that use panel voltages greater than 30V but not the systems that have 110VAC inverters on each panel.
Madoxen
thanks for your suggestion have had a little look but after something more aimed at 24v to 48v systems not 12v. although it is all the same stuff just bigger i guess, well except the cable thats smaller ;-)
Thanks Alloy my 550w panels are 49.3v have room for 4 of them so will prob series and parelel them the links to the spec sheet is on my build log if u wanted to see the nitty gritty
seth.c96
