... I don't think it matters for what you are building, but are you aware of polyiso insulation having less R-value in cold temperatures? https://www.energyvanguard.com/blog/59419/Big-News-The-R-Value-of-Insulation-Is-Not-a-Constant
Even if you do ever spend time in in -40 weather, it is easy to add additional heat, if you actually found yourself needing it.Yes I am.
But we are more concerned about insulation against heat, than insulation against cold...
Newport Solid Fuel Heater - Dickinson Marine
The Newport Solid Fuel Heater is a small stainless steel solid fuel heater designed for casual use ideal for boats 20-25ft. This heater burns one to two 1” thick wood or presto log, a handful of charcoal briquettes or coal. Removable ash drawer and damper control. Requires 3” diameter chimney...
