Exhaust Manifold compatibility
Does anyone know if the SOHC 3.5, DOHC 3.5, and 3.0 exhaust manifold is interchangeable? Any differences in years or if it's a sport or not? I have a 97 SR with a SOHC 3.5, there's a 95 LS with a 3.0 at the junkyard, should the manifolds swap over?
They appear interchangeable based on the description. This is on mitsubishipartswarehouse.com
**Edit- it says 3.0 but I don't see 1995 specified, so now I'm not sure, either ?
Salonika
Monterror Pilot
I’d guess they would be the same, knowing Mitsu and the platform.
I’d guess that even though the engines are different they are mounted in the same way using the same mounts and the rest of the exhaust would need to be the same because the truck is basically the same through those years. I’d take the risk.
  • Like
Reactions: plh
RyanY
I would think that the 3.5 DOHC manifolds would be different as the heads are physically wider than the SOHC heads, which means the manifold would have to have a different angle to meet the Y-pipe. Then again, maybe just the Y-pipe is different...
gp01
