SOLD - 2005 Toyota Landcruiser - $13,000
High Country Nomad
Mountain Explorer
Just listed my Cruiser today because I've been trying to get into a 1st Gen Tundra for a while. Wife won't let me have both so I need to sell this very well maintained touring vehicle.
Currently has 284,000 on the odometer. I only use this truck for camping and once a week to get our mail.
See below description of what's new in the past 12 months.
Bump It Offroad Dual Swing Out Bumper (Comes with 2 Jerry Cans)
Slee Heavy Rear Springs
ARB Front Bumper w/ TJM Lights
Come Up Seal 9.5 Winch with Remote
Group 31 Battery/ Slee Battery Tray
Escape Gear Seat Covers
ARB Wiring from Battery to Rear for Fridge
New in the past 6 months:
Brakes
Good Year Duratracs (5)
All Fluids Changed
Eezi Awn Load Bars (3 Months Old)
Slee Sliders (2 Months Old)
Cascadia 4x4 Solar Panel (June 2020)
Extras:
Yaseu Ham Radio w/ Antenna
TJM Portable Air Compressor
Olive Green MaxTrax
$14,500 gets you the ARB Drawers & ARB Elements Fridge
Would consider trade on 2006 Tundra.
Below is a record of all maintenance I still had a record of.
Date of Service Service Performed
9/25/2009 Transmission Flush
11/21/2009 Engine & Diff Fluid Change
Timing Belt
Idler Pully/Tensioner Pulley
Gear Oil
Spark Plugs
Coolant Flush
Power Steering Flush
1/18/2014 Power Steering Flush
Gear Oil
Fuel System Clean
Rear Diff
Transfer Case
3/3/2016 ARB Torsion Bar Set
OME Rear Coil Spring
OME Comfort Shock
Slee Diff Drop
90K Service
Oil Change
Transfer Case
Wheel Bearing Grease
Brake Fluid Change
Coolant Flush
Fuel Filter
Spark Plugs
Timing Belt
Water Pump
Heater T Change
100K Service
Timing Belt Tension
Serpentine Belt
Front Crank Seal Gasket
Hub Gasket
Hub Seal
Spindle Seal
7/15/2016 rear rotors
brake pads
9/7/2017 Recall - Airbag Sensor
6/4/2018 Odyssey 35-PC1400 Battery
CV Axle
Instrument Cluster Repair
Safety Inspection
Diff Fluid Change
Sway Bar End link bushing
Ball Joint Inspection
10/10/2019 ARB Front Bumper
ARB LED Fog Light
Comeup Seal Gen2 9.5RS
Factor 55 Flat Link
Slee Battery Terminal Kit
Slee 2; Rear Coik Spring Heavy
TJM Driving Light - 8" Clear HID 60 Watt
11/15/2019 Good Year Duratrac Tires
* There are dings and small scratches around the truck but nothing that can be seen from 10' or further. Minimal rust on certain body parts, but basically no frame rust. There is a square cut out in the rear tailgate carpet as I was attempting to add a storage hatch and realized it was the wrong spot. I glued the carpet back down and planned on installing a cutting board instead but decided to sell before I got that far.
High Country Nomad
Mountain Explorer
Interior Pictures added.
