For sale: Conqueror UEV-490 Extreme Platinum edition with loads of options.
Asking price: $49,900. This is lower than base price of a new UEV-490 with no options, and this trailer has many options to make it a great off road trailer
Are you considering buying a new Conqueror UEV-490? If so, consider this UEV-490, which was purchased new from Conqueror 4X4 USA in Bellafontaine, Ohio in March 2020. It was used once, has a mere 625 miles, and has been stored in a garage full time. We paid $63,505 for this unit. Owners are non-smokers and have no pets.
We chose the Platinum Edition and added the following options:
Two 100 Amp hour Lithium batteries
245 watts of solar on roof
Two 160 watt portable panels
Force air propane heater
Dometic air conditioner
On demand hot water
Bundatec 360 degree awning
Radio
Two 12v interior fans
Details of the UEV-490
Suspension, chassis and brakes
7,700 lb stub axle with Bilstein heavy duty shocks with independent suspension, coil springs and torsion bar
Hot dip galvanized ladder chassis
Electric 12″ brakes
Max Coupler Off-road coupling
LED rear tail lights
Marker Lamps
Adjustable Stabilizers, to stabilize unit when leveled
Adjustable Bosal stabilizer
Wheels/tires
Alloy wheels -Cooper All terrain tires
Full size spare has wheel bracket serving as extra stub axle
Sleeping arrangments
2 sleeping areas inside the trailer
Front: bow tent with flysheet and fold out double bed (1.8m length)
Inside camper is a fixed 2m x 2m sleeping area. This area is multi-functional— it can be a large bed or a dinette with table and bench seats. It can be either one large bed, or two smaller beds
When the driver side awning room is set up, you could also have additional room for sleeping outside the trailer in the awning room.
All bedding is high density foam mattress, covered in durable Conqueror branded covers
Conqueror Branded Bed linen, fitted sheets, covers, pillow and pillow cases are included— these have never been used and are in separate bags
There are two 12v interior fans to make sleeping more comfortable in warm weather
Electrical/water
Neutron 12 Intelligent Power Management system
We opted for Lithium batteries. There are two 100 Amp hour RELiON lithium batteries.
To charge the batteries, there are Solar panels on roof: 245 watts. The solar charger is included in the Neutron power management system. It also includes charging capability when plugged in to shore power (30Amp cord with adapter for 20Amp standard household receptacle are both included). In addition, you can also charge from your tow vehicle (this is controlled by the same Neutron power management system). To do this you will need to have a large gauge wire coming from tow vehicle, which connects to trailer via an Anderson plug. David Bates (owner of Conqueror USA as well as 4D solar) has an instruction sheet detailing what is necessary to do this, which I am happy to give to you. Finally, you can add additional portable solar panels if the trailer's solar panels are in the shade.
There is an included 300 watt inverter for supplying AC power inside the trailer from your batteries.
There are two Hella plugs (one on each side of the trailer) where you can plug in the included portable LED lights with 3m extension and Hella adaptor.
There are also LED lights mounted to the trailer on each side. There are three LED lights inside the trailer as well. Both the external mounted lights and internal lights can be either white or amber in color.
Anderson plug with 16mm wire connected to batteries for vehicle or solar charging
130 liter water capacity (~34 gallons)
Kitchen/cooking
There is a rather large awning room which can be deployed on the driver's side of the trailer.
In addition, if you don't want the awning room but just want additional shade you can deploy the UEV-490 Bundutec 360 degree Awning.
There is an aluminum camping table stored inside the trailer and can be used in the large driver side awning room.
The slide out section has a Dometic Stainless steel 2 burner stove as well as the 85L Stainless steel SnoMaster Fridge/freezer. At the end of this is a sink area with 2 removable plastic bins. The faucet has hot and cold water (there is a 12 volt water pump)
There are both cutlery and crockery drawers with included cutlery and crockery
The fridge is an 85L Stainless steel Snomaster Traveler series fridge/freezer with removable baskets and separate areas for fridge and freezer. There is an included remote so you can monitor status from your tow vehicle
There are pouches on the door which allow for additional storage. There is also a fold down storage area which can store items such as bottles of wine.
The pantry is on the driver side towards the rear. As mentioned, this is accessible from inside the trailer or outside. It has a fold down shelf as well.
Awning room on passenger side of trailer
There is a smaller awning room on the passenger side of the trailer. This side has slightly different walls as well as a divider wall that will allow you to use the external shower on that side of the trailer. This is also an ideal spot for a portable toilet (not included).
We elected to have the optional Dometic air conditioner (Dometic 7000 BTU split air conditioning system), which is housed in the storage area on this side of the trailer. The vents enter the trailer near the front fold out bow tent. This can be run only when you are connected to shore power (30 Amp).
Other exterior features
Wood rack
Jerry can holders and Military spec Jerry cans (Green)
Two Entrance doors with fold out steps
Aluminum Stone Protection
Rally tent & side panels included with 3 windows and door (all with mosquito netting)
Other interior features
Carpet on floor
Roof insulation
Storage
Propane tank storage bin with room for two 20 lb propane tanks. Includes tie down for securing the tanks
Aluminum nose box with access doors on each side of trailer. The continuous hot water heater (Propane) is mounted on the passenger side door of this nose box
Two rear external storage compartments
Lots of storage areas inside the trailer. These have zippers on the sides and velcro at the top.
The pantry is accessible from outside the trailer in the kitchen area but can also be accessed from the interior of the trailer
Other conveniences
Gas struts for roof lifting
Mountings for hatchet and spade (both are included)
Eyelets for fastening of cargo to lashing rails
Mud flaps
2 mesh like groundsheets - these are awesome. Let dirt filter through. One is still in bag and was not used on our lone trip.
Mosquito netting in windows and separate mosquito netting is included to go over the two doors to the trailer.
Interior pressurizing blower, creating positive air into unit reducing risk of dust leaking in while driving
Air conditioning: Dometic 7000 BTU split air conditioning system (see above)
Propex propane heater
CD/DVD/MP3/ FM radio
On demand hot water
Radio
Electric 12″ brakes
Marker Lamps
Wheels/tires
Electrical/water
Kitchen/cooking
Wood rack
Carpet on floor
Roof insulation
Storage
Other conveniences
Mud flaps
