Decided to keep the 05 G500, do a mini restore (neglected maintenance) and build it for more hard core offroad!
Maintenance ~150k miles:
Front axle cv/seals rebuild
engine valve cover seals and other gaskets that were leaking a bit (its no land rover after all)
TC oils and all new oil seals
Plugs
Transmission service
refreshed coolant systems and belts with all new OEM parts except the radiator
VTS heavy duty pulleys
Diff oils
Fun stuff:
Thor springs back on (actual 3" lift)
Poly bushings throughout
Castor correction bushings from eurowise
VTS adjustable panhards front and rear
VTS exhaust resonator delete kit
Fox shocks
VTS rear bumper, rock rails, sill protection and TC plate
VTS diff covers (yet to be installed)
MB OEM tow pin bumper on order from Germany through ORC (The old school version requiring a relocation of the Transmission oil cooler)
Warn 9.5xp winch with tow pin carrier and rear carrier from VTS. Wired both with Warn quick disconnects so I can move the Winch front or rear as needed.
Braid winrace S 8*17 wheels, planning to run 295/70-17 BFG KM3s
Some pics
Plugs
Diff oils
Fun stuff:
Fox shocks
Some pics
