Price range on a 4x4 Conversion for a 96 E350?
tedujam
I'm looking at two vans right now:
2001 GMC Savana Quigley high roof, 76k miles, cargo van, very basic, $14000
or
1996 E350 extended high roof wheelchair van, 102k, power everything, $5500
My goal was an extended high top 4x4 van, under 100k miles, for $15000. I like the Savana Quigley 4x4, but it's not extended. If I can get the E350 converted to 4x4 for under $10k, I'd probably buy it, but all the quotes I see for 4x4 conversions range from $8 -25k.
Advice?
SDDiver5
DIY or find one that is already converted. Lots of ski towns have them used with around 100k.
10k is for sure the starting point.
tedujam
Thanks. I've been looking nationwide for 3 months and these are the two best solid options I've found. Don't really want to keep searching for a year. Every time a good deal pops up, it's either a scam or someone snipes it within the hour. Vanlife is creating serious price inflation.
SDDiver5
I feel you...one of my wifes friends was in the same boat as you are. She's been looking for a year plus for exactly what she wanted and her price range. The vans that were right came and went in an instant. So, she ended up buying a regular, low mileage cargo van that was a cable company fleet van, 2wd, not built out and she's just gonna wing it. She's been traveling around Mammoth mountain in CA for like 3 weeks now and is loving it.
REALLY ask yourself if you NEED 4x4...If you really want to do this just buy a van, throw on some offroad tires, get a shovel and some max trax and just go... then save up some money and either go 4x4 or install a locker for like $1500.
Also, Think if you really want a cheap 4x4 conversion....
tedujam
Thanks. I'm not new to 4x4 (I have older Wrangler and 4Runner 4x4s) and I think the kinds of places I plan to take the van will be problematic for a 2WD w/locker (offroad, beach, snow, etc).
pugslyyy
With a $10k budget you are looking at doing it yourself with junkyard parts or a F350 donor. There is a lot that goes into the 4x4 conversion...
front axle, springs, fuel tank trim, drive shafts, transfer case, adapters, crossmember modifications, etc. I did mine myself (UJOR kit) and spent well over $20k.
tedujam
Or this....Not quite what you want but cheap!
Looks like a cool project, but there's gonna be a ton of rust and $15000 for 140k miles seems high to me, even with Vanlife inflation.
I like Astros, my parents had one way back, so I know they aren't big enough for my needs, plus if they don't list the mileage, it's usually sky high.
edit: mileage from the pics is 237k.
68camaro
Any River...Any Place
Agreed, I Iooked at converting my 2001 E-350 SD Chinook to 4x4. Using a F-350 donor vehicle and local shop was $12k, with end cost probably more and questionable drivability. Reputable and well known shops to this forum quoted low to mid 20's for proper conversion.
End of day I opted for lift, beefed up suspension, better tires and recovery gear. Really haven't seen need to have 4x4 yet but due to rigs size I can only get into so much trouble.
tedujam
Thanks to freeagent, there's another contender:
vs
2009 Ford E350 low roof 51k miles - Ujoint 4X4 conversion. 5.4L V8. Aluminess ladder. Vantech rack. ARB sun shade/rain canopy. 2000 watt true sine inverter and 200 amp-hour house batteries will run computers, power tools, fridge/freezer, etc. Removable interior cargo rack. Excellent mechanical and cosmetic condition. Air conditioner blows cold. $21000
Thoughts?
bgflyguy
Can you break down the cost a bit? I'm pretty naive when it comes to van work, but I would have guessed a complete DIY for ujor would come in at $10-$15k.
This should help break down price for an Econoline 4x4 Conversion...I converted a 2006 Ford E350 Turtle Top (basically a small shuttle bus) last year. This is my breakdown of the costs that I had for the 4WD Conversion. Keep in mind the prices from Chris at Ujoint Off Road are from last year and before he started selling everything in bundles.
CategoryItemDescriptionVendorDate of PurchasePrice
4WD ConversionLift KitUjoint Off Road 6" Lift KitUjoint Off Road
12/18/18 12:00 AM​
$5,819.85​
4WD ConversionConversion InstallCustom fabrication/installation of Ujoint kitBaker Garage Volvo Specialist
5/21/19 12:00 AM​
$1,828.76​
4WD ConversionShifter/AdapterTC001 Shifter & TC110 AdapterUjoint Off Road
5/20/19 12:00 AM​
$917.95​
4WD ConversionRear DriveshaftCustom Built DriveshaftFront Range Drive Line Inc.
7/8/19 12:00 AM​
$552.46​
4WD ConversionFront Axle2004 Dana 60Craigslist
1/15/19 12:00 AM​
$500.00​
4WD ConversionExhaust RerouteRerouting exhaust around driveshaft and transAll American 4WD
7/24/19 12:00 AM​
$425.00​
4WD ConversionTireGoodyear Duratrac 285/75r18Discount Tire
5/22/2019 15:05​
$289.00​
5/22/2019 15:05​
$289.00​
5/22/2019 15:05​
$289.00​
5/22/2019 15:05​
$289.00​
4WD ConversionFront DriveshaftLengthen and Rebuild DriveshaftFront Range Drive Line Inc.
11/13/19 12:00 AM​
$216.25​
4WD ConversionWheelBlack Rhino Armory - Black 18x9.5 8-170Discount Tire
5/22/2019 15:05​
$199.00​
5/22/2019 15:05​
$199.00​
5/22/2019 15:05​
$199.00​
5/22/2019 15:05​
$199.00​
4WD ConversionTransfer CaseTransfer CaseBaker Garage Volvo Specialist
5/7/19 12:00 AM​
$100.00​
4WD ConversionTie Rod EndMoog DS1439 Tie Rod EndAmazon
6/1/19 12:00 AM​
$98.79​
4WD ConversionFront Driveshaft2004 F350 DriveshaftCentral Auto Parts
5/30/19 12:00 AM​
$95.86​
4WD ConversionBall Joint LowerMoog K8607T Ball Joint Set of 2Amazon
5/7/19 12:00 AM​
$81.30​
4WD ConversionBall Joint UpperMoog K80026 Ball Joint Set of 2Amazon
5/7/19 12:00 AM​
$64.44​
4WD ConversionTie Rod EndMoog ES3423 Tie Rod EndAmazon
6/1/19 12:00 AM​
$42.70​
4WD ConversionBall Joint InstallPress upper/lower ball joints on custom knuckleColorauto
6/4/19 12:00 AM​
$40.79​
4WD ConversionLug Nut KitGorilla Wheel lock/lugs 14x2.0Discount Tire
5/22/2019 15:05​
$35.00​
4WD ConversionTrans BearingFord 3C3Z-7B368-AA BEARINGOmeara Ford Parts
6/27/19 12:00 AM​
$28.92​
4WD ConversionT-Case PlugFord 6C3Z-7A010-A PLUGGroove Ford Parts
7/10/19 12:00 AM​
$7.34​
Total
$12,807.41​
Here's the thread of my build too...before it got totaled last December :cry: https://www.expeditionportal.com/forum/threads/2006-e350-van-terra-build.201418/
It took me about 4 months to find a new replacement for my rig, but 2 weeks ago I just picked up a stock 2013 Ford E350 V10 Extended Passenger van with 103,000 miles. I'm planning on doing the same 4x4 conversion next year. For now i'm buying a Super Camper high top from Fiberine with an install date for September 1st!
Lockwoodjd
