2019 Custom RV Conversion, F350, 4x4, 7.3L Diesel
bad_andy24
For Sale: 2019 Custom RV Conversion, F350, 4x4, 7.3L Diesel
Condition: Newly Renovated!!!
Price: $107,288 OBO
Contact:
theambo24@gmail.com / IG:the_ambo
Vehicle Base
2001 Ford F350 Superduty Cab and Chassis, DRW(Stock/Unmodified) 144,000 miles +/-
7.3L Powerstroke V8 Turbo Diesel Engine(Stock/Unmodified)
4x4 Limited Slip Transmission w manual locking front hubs(Stock/Unmodified) 72,000 mile +/-
Dual Yellow Top Optima Starter Batteries
Dual High Output Alternators
Engine Powered Rear HVAC Unit
Crawl thru from cab to Box
Exterior Upgrades
New Paint - Complete Color Change Single Stage Paint
TOFF Bedlinered Trim, Roof Rack and Accents
Telescoping Tow mirrors w/ heat and turn signals
12'x7.5' Custom Aluminum Roof Rack & Ladder
ARB Front Bumper
Smitybilt X2O 17500# Waterproof Winch
Spyer Headlights
Raptor Conversion Grill with lights
Dual 50'' lightbars(front/rear)
12' Dometic 200 (9500 Series) Hard Case Manual Awning
Dual Rotopax 2G Fuel Cannisters
Box/Living Space Custom Interior Upgrades
Webasto Dual Top Evo 6 Diesel Air/Water heater
TrueInduction Mini Duo Glass Cooktop
Dometic Convection Oven/Microwave
Dometic CFX-75DZW Dual Zone Fridge/Freezer
Victron MultiPlus Compact 12/2000/80-50 120V VE.Bus Inverter/Charger
Victron Energy BMV 712 Smart Battery Controller w/ Bluetooth
400ah LiFeBlue Lithium House Batteries(space to add an additional 200ah battery)
SerenLife Portable Cassette Toilet
15'' Sink w/ Drying Rack, Cutting Board Insert & Mirrored Backsplash
Queen Size 6'' Memory Foam bed
Custom Sunbrella Upholstery and Mattress cover
White laminate cabinets w/ SS Yacht grade pop latch knobs
White Oak Ceiling and Trim
White Oak Butcher Block Countertops w/ matching Table Top
MaxxAir Deluxe Thermostat controlled roof vent fan
(2)Tern Overland Acrylic windows with shade/screen Blinds
30gal freshwater tank
6gal greywater tank
10' interior fly rod tube
LifeProof Laminate Floor
weBoost Drive 4G-X RV Cell Phone Signal Booster
30 amp Shore Power Inlet
Custom Black-out, Insulated Removable Window Shades to Match Upholstery
Solar Ready(just add Panels and Controller)
Cab Interior Upgrades from Stock
09 Ford Lariat Heated Power Seats with New Covers
09 Ford Lariat Center Console
Kenwood Excelon DNX994S Touch Screen Stereo with Apple CarPlay, Rear Back-up Camera & 8" Powered Sub-Woofer
New cab carpet w/ Sound Deadening/Insulation Mat
WeatherTech Molded Floor Mats
Custom Switch Console
Engine/Chassis Upgrades from Stock
Fox 2.0 Performance Series Remote Reservoir Shocks
BDS Suspensions Front Leveling & Dual Fox Stabilizer Kits
SBCC 8 piston Heavy Duty front brakes
4'' exhaust all the way to the turbo
(7)Toyo Open Country A/T Tires w/ Spare 285/75/R16
Vision HD Hauler Dually Wheels
(4)New Tire Chains
Heavy Duty Tow Hitch w/ wiring
D
Deleted member 67976
Guest
I'd consider trading my 1998 E350 7.3L LWB RWB Sportsmobile with 144,000 miles for this good rig
ovrland6250
Sweet build! Is all of the plumbing 4-seasons ready? Is the 7.3 the factory motor or was it replaced with a crate motor (I see on the spreadsheet a value assigned to the 7.3). Thanks
bad_andy24
Yes, all of the plumbing is inside the large compartment on the driveside of the box. Under the sink basically. The Webasto unit is in the same box and it has an auto dump function for the heat exchanger inside in case the water temp drops to low so the heater cant freeze up.
Yes. The 7.3L is factory. I am the second owner of the rig itself and have 122 pages of maintenance records for the truck as well.
mk216v
Der Chef der Fahrzeuge
Gorgeous build, well done! Love the modern aesthetic.
How many miles on this rig?
Thanks for posting the full spec sheet details. Many higher end components.
Forgive me but I'm not understanding the pricing listed or sales price. Are these prices listed the original MSRP's? Something like the factory 7.3L at $3205 or the factory 4x4 w/ manual locking hubs at $2290--is that what Ford charged back in 2001?
ARB bumper at $3183 (currently available for less than $1800).
Dometic fridge at $1849 (currently under $1100).
2 Ternoverland windows at $1958 (most expensive windows they currently sell are $1178/pair)
Just trying to better understand your pricing evaluation, thanks.
bad_andy24
mk216v Thanks for checking out the post! Still need to add more detail photos.
The 7.3 motor and chassis has right at 144k miles on it and the trans is right at half of that. I can give you the exact numbers if you need them just dont have that info in front of me atm.
You are correct. I went back and looked up the original MSRP values for the 7.3 and 4x4 on the truck then depreciated them for age. Basically just wanted to illustrate the the value of the base rig is in the 7.3 motor and the factory 4x4 more so than the 2001 model chassis. All of the component pricing listed includes the item, shop supplies, install labor and any fab work that went into fitting them into the build. Obviously there are plenty of small components required to make everything work together smoothly that aren't listed. Just didn't wanna bore everyone to death listing every little thing. Basically those prices are an installed sales price, not what you can purchase the items for retail before tax and shipping.
Thanks for the questions! Let me know if I can answer anything else for you!
Andy
Petersmithinak
