Taxa Wooly Bear
Sawyer
Finally got some time to see how this tongue box might work on my WoollyBear trailer from Taxa Outdoors. Had to move the tongue jack forward about 1/2” which is the most I can move it. The actual receiver hitch is unfortunately welded on (for now). Anyways, the box fits very nicely. The width is perfect. The lid opens nicely.
Now I have three things to work out:
1. How to mount it so that it is stable and rugged. There is no triangle tongue.
2. The jack handle can’t rotate to raise and lower.........that’s an issue! So I need to figure out the jack. I was thinking of changing it to one with a wider wheel that moves on soft ground without sinking so much. Now I may need to look at all of it.
3. Battery fits inside with lots of room. I picked up an inverted as well. So I need to start to plan my electrical system. I want USB and cig plug style outlets in the rtt. As well as solar charging system.
So, next weekend I’ve got lots to work on!
what box did you put on there and any long term thoughts? Just got a new Wooly Bear myself (well Santa will deliver on Christmas?) and a bigger tongue box and multi-axis coupler are on my mods list. Thanks!
kchan628
I have a 2020 Woolly Bear arriving in a few weeks (fingers crossed). I was wondering if anybody has installed a brake controller for it? I know it comes with electric brakes but no brake controller.
dart330
Did you have to splice wires for that?
When you pull the plug apart, each pin has room for two wires under a tab held by a center screw. I added the autowbrake wires to the other side of the tab. Just completed a 1k mile drive and it really made a difference.
V45W_Proto2.5
