2015 ram headlight bulb question
Luckychase5
So my low beam bulb went out. Is there a better bulb people like and use? Or should I just replace it with a stock unit?
Luckychase5
Sorry, I should have said this, but in the “Black Appearance Package” I have the Bi Projector Headlights. But I appreciate know this will be a PITA to change, so I’ll order all new bulbs. Cheers
Luckychase5
Ordered some Philips low beam and Sylvania High Beam bulbs. We’ll see how they do
Hilldweller
SE Expedition Society
Wish I saw this earlier.
You can replace both high and lowbeams with brighter (and legal) bulbs by slightly modifying the bases.
It's a significant improvement.
How to modify:
For the HIR highbeam: https://sep.yimg.com/ca/I/yhst-91565365470012_2267_311973
For the H9 (2100 lm vs the stock 1350 lm), just use a dremel or sharp knife and cut off the plastic fin that runs down the middle of the bulb's female socket.
Hilldweller
Dang; I didn't see this post at first. The advice in my previous post if for the quad-halogens with parabolas.
What bulbs are stock in the projectors?
Luckychase5
Low beams are HIR2
High Beams are 9005
Luckychase5
Cool. You can replace the 9005 with an HIR-1 then. The HIR-2 is good the way it is.
The LL versions are weaker output to last longer. I'd rather use good bulbs and replace them annually.
Will I need to do any modifying to make that adjustment to HIR-1’s?
