(SOLD)2020 All Road Timbren Axel-Less Teardrop Brand New $15,000 L.A CA
Rad Coast
Trailer features
-13 inches of clearance (without spare tire) 4 inch Lift spindles available from Timbren
-5x9 foot trailer 13x6.7 feet overall 68 inches tall from ground
-Under 1200 lbs dry
-2x2 NATM certified welded steel frame
-Timbren 2000 lb axel-less suspension with heavy duty spindles and break flanges (upgradable to breaks)
-15 inch radial trailer tires with spare underneath
-2 inch ball
-2 inch rear receiver
-Led tail, marker and license plate lights on 4 pin plug (upgradable to 7 pin)
-Rear levelling jacks and front trailer jack with wheel and flat plate included
-Solid once piece floor with fully diamond plated underneath
-Painted aluminum .040 skin over a full birch construction
-Fully insulated 1.5 inch R-Tech foam board walls, roof and rear galley hatch
-2 30x36 inch doors with 16x26 inch half sliding screen windows
-9x45 inch skylight/stargazer window (new non leaking style)
-2 led porch lights with switches inside
- Tongue box with battery box and switch inside (room for additional batteries)
-Vmax Charge Tank fast charge deep cycle 100 ah AMG battery (the best AMG
battery on the market)
-Progressive Dynamics 4045 power converter 3 stage battery charging wizard that will also charge lithium batteries (new style)
-30 amp shore power with 30 to 15 amp a
Cabin features
-56x78x43 3/4 inside (without mattress)
-Everything is built from Baltic birch finished in low voc water based polycrylic
-6 inch full size memory foam mattress with removable cover
-10 speed Maxxair fan that pushes or pulls air in or out with built in thermostat
-3 large cabinets and 2 drawers
-Electronics cubby with 4 USB cartridges (2 fast charge) battery voltage monitor, 2 110 power plugs with 2 more USB chargers when connected to shore, generator or inverter power (inverter and generator not included)
-4 Recessed warm LED lights on two switches
-2 led dimmable reading lights with USB chargers built in
Galley features
-All built from Baltic birch finished in low voc water based polycrylic
-58x24 main galley counter covered with vintage pattern Formica
-Large double 22 inch stove slide (44 inches overall) covered with vintage pattern
Formica
-3 storage drawers a large 22 inch deep one and two smaller ones
-Large 22x26 inch cooler slide with 12 volt power plug underneath built for a Yeti 45 or dometic cfx 35w it’s also storage for the side tables
-2 18x26 side clip on tables finished in vintage pattern Formica
-1 GFI 110 plug in (must be connected to 110 shore power)
-2 USB chargers a 12 volt plug and battery voltage monitor on a switch
-4 recessed warm LED lights on two switches
-Hatch is on two gas shocks, two locking handles and is fully insulated and waterproof
More options www.raddwellings.com
Rad Coast
Here are the rules for posting something for sale on Expedition Portal
This section is for forum members to sell individual items that they already own.
If you are a company wanting to sell items as part of your revenue generating business, if you are an individual selling a large number of the same items or repeatedly selling the same type of items, or if you are a non-profit pursuing donations you will need to first contact us to become a contributing sponsor of Expedition Portal. For details and contact information please visit http://expeditionportal.com/partner-with-us.
If there is any question regarding the validity of your sale or your status as a non-contributing business your thread will be locked and you will be contacted for further clarification.
You are considered to be a business if you:
1. Are trying to sell any products not in your immediate possession
2. Are trying to sell a single product which is NEW and in a quantity greater than 5 units
3. Are trying to sell a single product which is USED in a quantity greater than 10 units
4. Repeatedly sell similar items on a regular basis
5. Reference your own website external to your post for more information, products or services
6. Have a post count less than 50.
Alright, I had seen on here someone selling trailers not built yet, I do have the red one in the ad in my possession.
Thanks
