TRADED: '08 Pathfinder - V8 - Griddle - Bed - Go See Joey Parent @ BOULDER NISSAN!!!
N.Y.X.
Traded in at Boulder Nissan!! Go See Joey Parent; he got me a great deal on a new TITAN!!! 0% APR and a great deal off MSRP!!
VEHICLE INFO:
All Maintenance/Service Schedules are up to date.
2008 Nissan Pathfinder LE
VIN: 5N1BR18B98C607319
MILES: 107K
Clean CO Title in Hand
5.6 L V8 Storm Gray Metallic K-27
310 hp @ 5200 rpm
388 ft-lbs. @ 3400 rpm
2.91 Gearing w/ Open Diffs.
PICTURES/Build: https://expeditionportal.com/forum/...heater-sleeping-platform-sink-sprayer.192397/
The Bad:
~Body Panels have some scratches, dings, dents, etc. It's an off road rig.
~Rear Transfer Case Seal needs to be changed. Very, very slow leak. Fluid Included.
~Driver Side Differential Seal needs to be changed. Very, very slow leak. Fluid Included.
~Minor Accident reported, see build page for accident photos.
~Small, 2" tear on Driver Side seat.
~Windshield has multiple cracks.
~Exhaust bracket needs to be cut and re welded so transfer case skid plate will fit.
~Tire Pressure Monitoring System Sensor needs replaced if you care.
AT 98K MILES:
~Volant CAI
~CFS Aluminum Radiator
Flush/Fill
~Matic S Transmission Flush/Fill
~Matic D Transfer Case Flush/Fill
~Royal Purple Differential Flush/Fill
~NGK Iridium DILFR5A11 Plugs
~Belt Tensioner, Belt, Cabin Filters
~Fuel Gauge Sending Unit
~1.5" Wheel Spacers
~Brunton Solar Trickle Charger
~NissTec Lifts MK84 Lift: MK84 Coilovers / 1" Spacers, SPC UCA's, F/R Stainless Brake Lines, OME Rear Shocks, IRON MAN HD Rear Lift Springs, SPC Front Cam Bolts
At 100K
~BF Goodrich KO2 265/70/18
~Aluminum Hefty Fab Skid Plate Set
~3 - 20" Single Row Super Bright LED
~30" Single Row Super Bright LED
~270 Degree Awning w/ Walls
~Flush Mount Aluminum Roof Rack
~InSain Fab Sliders
~Working Snorkel V6 - V8 conversion
~AutoCraft Platinum AGM Battery, 710CCA
~Inner/Outer Tie Rods + Alignment
~Added Switch Panel and USB Chargers
~Parking Brake Pads
~Weathertech Mats
~High Output Fog Lights w/ Snow Tint
Camping:
~Pull out Black Stone Griddle and cooking platform
~Large Drawer
~Full Size Bed Platform w/ 4" Topper
~12 Gallon Water Tank w/ Pump; 2.9GPM
~Blue Sea Fuse Box
~Wired Front/Rear and Alley Lights
~Propane Tank Mount
Extras:
~3.36 Front Differential Gears for M205
~OME MD Lift Springs
~Driver Side, Rear Door
~M205 CV Shafts x 2
~3rd Row Seats
~Transfer Case, Transmission & Differential Fluids
Not Included:
~Pelican Case
~RAINGLER Nets
~Bike Racks
~Propane Tank
~Skeeter Beaters
~Shovel/Axe
N.Y.X.
LI have a few other projects to wrap up; but ordered AFE Controller, AFE Intake, AFE Cat Back, 1.5" Wheel Spacers and Fender Flares:)
gp01
