Off road RTT Trailer - West TX
woodardd
Custom built
Timbres axle less suspension
Electric linear actuators with four corner fast struts. Pin lockouts, for lift system.
Water and fuel holders
Leitner gear pods up front
Stabilizing jacks underneath.
Rear custom swing gate with spare tire.
Tepui RTT - trailer can be sold without tent
Kevlar truck tires
Just toted this 1,500 miles hunting CO and NM. No issues. Can go anywhere.
Moving towards enclosed trailer system for ATV and sleeping.
$8,000 all in with tent. Will meet within reasonable distance.
Pm me with questions, etc.
xaman
What Is the height of the available space between the deck and rack?
what is the tire and wheel size, and bolt pattern?
thanks.
woodardd
thanks.
I’ll have the to check the height between deck and rack. I’ll check it at the lowest level. This can be easily manipulated if you decide to raise the rack. You can drill more holes in the rack corner lift tubing at whatever height you want for the pin lockouts to sit into. This would give you as much height as you wanted while traveling.
As for tires size, they are 275/70R16. 16 in wheels. I’ll have to check bolt pattern, but are 6 lug and probably 5.5. The tires came off of my 2018 Tacoma TRD pro, and are the factory Goodyear Kevlar tires.
Custom built
Kevlar truck tires
hey there... overall dry weight & tongue weight? not seeing any lights on the back, so it's not wired? also you mentioned that it could be avail w/o the tent; how much w/o it?
woodardd
Haven’t Wright it dry. It does have lights so it is wired. PM me if you are interested and we can discuss everything else.
zhukoveli
