Smittybilt Scout Trailer Reviews?
Kraxler
Where did you install it at? I bought a 21 gallon but its just too big... well its really too heavy for where I planned to put it.
I installed the tank between the swing arms, vertically. That is the long side down the trailer length then the next side vertically. Welded on 4 vertically posts with a metal plate on the bottom.
Kraxler
How about a few pictures, Including your hook ups and how you fill and vent it.
Here are some photos. I actually have 3 tanks mounted. A 9 gal between the axle and 2 10 gal further forward.
KatandBill
Thanks for the great pics, looks like a well designed system! What are the dimensions of the forward mounted tanks? Do you also have an on board hot water heater? I'm guessing there is also a common fill line
Kraxler
Here is the info from Amazon on the fron water tanks.
.Recpro RV water Tank 10 gal.
I have not installed a water heater yet. There is one filler mounted on the driver side next to my relocated front storage box. The vent for the tanks is up through the generator compartment over to the kitchen compartment. The hose is long enough to put outside the box when filling so no water gets inside. The pump is mounted above the driver side swing arm. Out of the way and protected. At he present I have a pot filler spigot in the kitchen compartment that is plumed through the main rear storage area out through the bottom of the trailer to the line coming from the pump.
trae
Late season camping. Light snow dusting but nice and snug in the tent
Pau Hana
Have any of you guys or gals purchased the Habitat Off Road On Board Water System? Didn't get any response the last time I asked so maybe no-one had purchased or received theirs yet. Just curious if anyone had any experience with or thoughts about the system?
bluerooster02
Has anyone been running the FSR High Country 80" or similar sized RTT on these trailers? SB isn't great with posting dimensions, I was just curious if you felt like additional bracing was necessary for the length.
OregonJKU
Hi, we have a Roofnest Eagle mounted on our Scout trailer, which is 85" long. So, we mounted bracing to the front of the main box. The attached picture is not great but should give you some idea of what we did.
bluerooster02
Thanks, my tent is 85" external as well. Looks pretty straight forward.
McDowra
I will probably do my own system that one seems a bit high to me
xander69
